Custom bit rate for CAN bus
The CAN library initialises the connection with one of four standard bit rates ( BR_125k, BR_250k, BR_500k, BR_1000k).
These are defined in ArduinoCore-API/api/HardwareCAN.h at master · arduino/ArduinoCore-API · GitHub
and used in the R7FA4M1_CAN::begin function.
The bus I want to connect to runs at a very low speed (16.7kbps) so I need some guidance on how to modify the code to support this bit rate.
I did this on the Adafruit Feather M4 CAN board as the initialisation routine allowed the bit rate to be input directly (rather than as a constant)
Has anybody else done this before, or do I need to figure it out bit-by-bit ?
Thanks
Those values ultimately get passed into a function calc_can_bit_timing where a loop figures out the closest figures to put into the 3 relevant registers ( baud_rate_prescaler, time_segment_1 (TSEG1) & time_segment_2 (TSEG2))
Yes, the source code also had a note referring to section 30.4.3, RA4M1 Group User Manual, which I had better go and read :slight_smile:
And I just found the thread you created showing where to access the source code for all types of registers in the underlying mcu.
I've got a feeling the CAN module will need to be in Reset mode for any change in bus timing to work. A shame the Arduino folks only support 4 bus speeds out of the box.
I've modified the enum for the bit rates and can get it down to 40kbps. Anything lower means the bounds on TSEG1 and TSEG2 are exceeded* so the function to start the CAN module fails.
Is it possible this mcu cannot support lower bus speeds ?
* From section 30.4
TSEG1 = 4 Tq to 16 Tq
TSEG2 = 2 Tq to 8 Tq
The code in the CanUtils.cpp needs an overhaul.
Following some help from the Renases forums I've hard coded the values to get this to work.
I will create a code change and make a PR in the github repo as I can't be the only person with this issue.
PR added to the github repo
And another PR to the github repo to support bit rate values which are just below (as well as just above) the theoretical rate.
