Custom character I2C LCD
I’m trying to do some character. These are: space, I, II, III and IIII. The result is quite different. Where am I doing wrong?
#include <Wire.h>
#include <LiquidCrystal_I2C.h> // F Malpartida’s NewLiquidCrystal library V1.2.1
#define I2C_ADDR 0x20 // Define I2C Address for the PCF8574A mjkdz
//—(Following are the PCF8574 pin assignments to LCD connections )----
// This are different than earlier/different I2C LCD displays
#define BACKLIGHT_PIN 7
#define En_pin 4
#define Rw_pin 5
#define Rs_pin 6
#define D4_pin 0
#define D5_pin 1
#define D6_pin 2
#define D7_pin 3
#define LED_OFF 0
#define LED_ON 1
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
byte v0[8] = {0b00000,0b00000,0b00000,0b00000,0b00000,0b00000,0b00000};
byte v1[8] = {0b00000,0b10000,0b10000,0b10000,0b10000,0b10000,0b00000};
byte v2[8] = {0b00000,0b11000,0b11000,0b11000,0b11000,0b11000,0b00000};
byte v3[8] = {0b00000,0b11100,0b11100,0b11100,0b11100,0b11100,0b00000};
byte v4[8] = {0b00000,0b11110,0b11110,0b11110,0b11110,0b11110,0b00000};
byte v5[8] = {0b00000,0b11111,0b11111,0b11111,0b11111,0b11111,0b00000};
int col = 0;
lcd.createChar(0, v0);
lcd.createChar(1, v1);
lcd.createChar(2, v2);
lcd.createChar(3, v3);
lcd.createChar(4, v4);
lcd.createChar(5, v5);
lcd.begin (16,2); // initialize the lcd
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,NEGATIVE);
// lcd.setBacklight()
lcd.setBacklight(LED_ON);
lcd.clear();
Serial.print(col);
lcd.setCursor(col,0);
lcd.write(byte(col));
col++;
if (col > 5) {
col = 0;
lcd.clear();
If you want a character to look like | | | you need white pixels (0) between the black pixels. So that would be 0b10101 in the array. ob11110 is almost a solid block. You won't be able to get | | | | in a single character.
You should define the chars after calling lcd.begin().
It's working! Thank You very much Whandall.
