I am almost done with my ECG but I am running into a problem where I get a negative frequency when im using FFT to find my heart rate. I want to use FFT to get amp, freq and phase so I can graph a waveform of my heart beat. What am I missing or doing wrong? I am using an ESP32 Heltec LoRa and ThinkSpeak to store the data and display the waveform
#include <WiFi.h>
#include <Wire.h>
#include "heltec.h"
#include "arduinoFFT.h"
#include "ThingSpeak.h"
#include <math.h>
// connect the signal to the pin 13 of heltec LoRa ESP32
arduinoFFT fft = arduinoFFT();
WiFiClient client_1;
// ************* Variables and WiFi SSID/PWD setup
const char* SSID_1 = "SSID";
const char* PWD_1 = "PWD";
unsigned long myChannelNumber2 = Ch2; //Collects Amplitude
const char * myWriteAPIKey2 = WriteAPI2";
unsigned long myChannelNumber3 = Ch3; //Collects Frequency
const char * myWriteAPIKey3 = "WriteAPI3";
unsigned long myChannelNumber4 = Ch4; // Collects Phase
const char * myWriteAPIKey4 = "WriteAPI4";
int status = WL_IDLE_STATUS;
const int FFT_size = 256;
const int Sampling_freq = 20;
const int Heart_Read = 13;
const int N = 6;
//float Signal;
double vReal[FFT_size];
double vImag[FFT_size];
double vPhase[FFT_size];
double x = 0;
double v = 0;
double peaks[N];
double phases[N];
double freq[N];
void setupOLED()
pinMode(RST_OLED, OUTPUT);
digitalWrite(RST_OLED, LOW); // turn D16 low to reset OLED
delay(50);
digitalWrite(RST_OLED, HIGH); // while OLED is running, must set D16 in high
Heltec.display->init();
Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
void setupWIFI()
WiFi.disconnect(true);
WiFi.mode(WIFI_STA);
WiFi.setAutoConnect(true);
WiFi.setAutoReconnect(true);
WiFi.begin(SSID_1, PWD_1);
//ThingSpeak.begin(client_1);
Heltec.display->clear();
if(WiFi.status() == WL_CONNECTED)
Heltec.display->drawString(0, 0, "WiFi Connected");
Heltec.display->drawString(0, 0, "WiFi Connection Failed");
Heltec.display->display();
Heltec.begin(true, false, true);
pinMode(25, OUTPUT);
digitalWrite(25,HIGH);
pinMode(Heart_Read, INPUT);
//Heltec.display->setFont(ArialMT_Plain_10);
delay(5000);
for (int k = 0; k < FFT_size; k++)
vReal[k] = (double)analogRead(Heart_Read);
//Serial.println(vReal[k]);
vImag[k] = 0;
delay(50); //Delay = 1000/Sampling_freq
delay(100);
fft.Windowing(vReal, FFT_size, FFT_WIN_TYP_RECTANGLE, FFT_FORWARD);
fft.Compute(vReal, vImag, FFT_size, FFT_FORWARD);
vPhase[k] = atan2(vImag[k], vReal[k]);
fft.ComplexToMagnitude(vReal, vImag, FFT_size);
fft.MajorPeak(vReal, FFT_size, Sampling_freq,&x,&v);
int Heart_rate = (int) (x * 60);
//Serial.println(x);
//Serial.println(v);
int n_peak = (int)((double)x * (double)FFT_size/(double)Sampling_freq);
//Serial.println(n_peak);
for (int cnt = 0; cnt < FFT_size/2; cnt++)
if (vReal[cnt] < 0.1 * v)
vReal[cnt] = 0;
int knt,cnt = 0;
double temp;
for(knt = 1; knt <= FFT_size/2; knt++)
temp = vReal[knt];
if ((temp > vReal[knt+1]) && (temp > vReal[knt-1]) && (cnt < N))
peaks[cnt] = (double) vReal[knt]/(double)FFT_size;
phases[cnt] = (double) vPhase[knt]; // * 180.0 / 3.141592;
freq[cnt] = (double)(knt * Sampling_freq)/(double)FFT_size;
cnt++;
for (cnt = 0; cnt < N; cnt++)
Serial.print(freq[cnt]);
Serial.print(" ");
Serial.print(phases[cnt]);
Serial.print(" ");
Serial.println(peaks[cnt]);
delay(100);
setupOLED();
Heltec.display->setFont(ArialMT_Plain_16);
String BPM = String("BPM: " +String(Heart_rate));
Heltec.display->drawString(0,10,BPM);
delay(5000);
delay(50);
delay(100);
setupWIFI();
for(cnt = 0; cnt < N; cnt++)
ThingSpeak.setField(cnt+1, (float)peaks[cnt]);
ThingSpeak.writeFields(myChannelNumber2, myWriteAPIKey2);
delay(15000);
ThingSpeak.setField(7, Heart_rate);
Serial.println("The heart-rate was sent to ThingSpeak");
delay(15000);
ThingSpeak.setField(cnt+1, (float)freq[cnt]);
ThingSpeak.writeFields(myChannelNumber3, myWriteAPIKey3);
delay(15000);
ThingSpeak.setField(cnt+1, (float)phases[cnt]);
ThingSpeak.writeFields(myChannelNumber4, myWriteAPIKey4);
delay(15000);
delay(300000);
//WiFi.disconnect();
WiFi.mode( WIFI_MODE_NULL );
