Hello,
I am working on a simple laser-based transciever and i have seem to have succeed in creating the circuit and the code, but I need help on 2 final steps of the programming part of the project.
Basically I enter a HEX character from a keypad and it sends it to the message preview LCD. The code has start and end markers ("<" and “>”) so it knows when you have typed the entire message you want to send over serially.
So, an example of a message looks like “” (without the quote marks) and the receiver will display on the LCD “CDF312A0” (again, w/o quotes).
What I need help with is the part where I want to assign an ASCII character to a certain pair of HEX symbols. For example, “CD”=A; “F3”=B; “12”=C; “A0”=D and so on. Therefore, the message you will encode and display on your LCD and the decoded message that the receiver will get will be “ABCD”.
Here is my code so far:
#include <LiquidCrystal.h>
LiquidCrystal lcdSend(2, 3, 4, 5, 6, 7); //declare arduino pins used on sending LCD screen
LiquidCrystal lcdReceive(A1, A0, 13, 12, 11, 10);
String message;
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
int thresholds[16] = {0, 79, 146, 204, 248, 294, 335, 371, 399, 429, 456, 481, 501, 522, 542, 560}; //voltate thresholds for each character key
char keypad[16] = {'1', '2' , '3', 'A', '4', '5', '6', 'B', '7', '8', '9', 'C', '<', '0', '>', 'D'}; //values assigned to voltage values
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
// if (Serial.available() > 0) {
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void showNewData() {
if (newData == true) {
Serial.println(receivedChars);
lcdReceive.print(receivedChars);
newData = false;
Serial.begin(1200); //start serial port
lcdSend.begin(16, 2); //setu[ sending LCD
lcdReceive.begin(16, 2); //set receiving LCD
lcdSend.setCursor(0, 0);
lcdReceive.setCursor(0, 0);
lcdReceive.print("Received");
lcdSend.print("Write here:");
lcdSend.clear();
lcdReceive.clear();
while (true)
lcdReceive.clear();
recvWithStartEndMarkers();
showNewData();
int value = analogRead(A4); //assign analog pin A4 to read the voltage coming from the keypad
for (int i = 0; i < 16; i++) {
if (abs(value - thresholds[i]) < 5) //if a voltage value is close (+/- 5) to one of the threshold, use it
while (analogRead(A4) < 561) //recieved voltage is in expected value range
delay(550); //wait 550ms before pressing another button
if (keypad[i]) { //if a key is pressed also show it on sending LCD
lcdSend.print(keypad[i]);
message += String(keypad[i]);
if (message.startsWith("<") && message.endsWith(">"))
Serial.print(message.length());
Serial.print(message);
As you can see, I am using a single analogue pin of the arduino receive the pressed button on the keypad and the serial receive protocol from the sticky post (very useful)
Do I need a special custom library for defining the characters I want to encode on the 2 HEX symbols? If so, can you point/show me an example, please?
//i’m not just using simple ascii codes because custom codes can be used as a form of encryption
Also, can you point out any good tutorials regarding my second issue, aka, how to get the cursor on the LCD to move to the second row of the LCD module when I enter the 17th character?
Thank you very much for reading. Any help is welcomed
