I have a quite unusual error, even if I’m coding in C for a while.
I discovered my problem by coincidence when one of my sketches runs out of space, after I changed only the file structure of my own libraries.
I’m using Arduino 1.0.5 and Atmega32u4.
Case 1: (separate folder for each Engduino library)
arduino/libraries/EngduinoLED/ {EngduinoLED.cpp, EngduinoLED.h, SPI.cpp, SPI.h}
arduino/libraries/EngduinoButton/ { EngduinoButton.cpp, EngduinoButton.h}
etc…
Result → size of test sketch (using some of that libraries) = 6KB.
Case 2: (common folder for all Engduino libraries)
arduino/libraries/Engduino/ {EngduinoLED.cpp, EngduinoLED.h, SPI.cpp, SPI.h, EngduinoButton.cpp, EngduinoButton.h , etc…}
Result → same sketch = 13KB!
Any explanation about it would be really appreciated!
With that file structure codes doesn’t compile, because it’s too large (29KB). But with different file structure, compiles without problems on size 24KB and also works without any problems.
