Custom Library
Hello, I am trying to create a library that uses soft wire to communicate with an i2c device. I have written this code that contains the header, source, and Arduino code in one file. The code works perfectly but when I separate each of these into different files (.h, .cpp, .ino), I keep getting errors such as undeclared variables and such. What is the correct way to declare the variables so that they have the correct scope?
#define SDA_PORT PORTD
#define SDA_PIN 2
#define SCL_PORT PORTD
#define SCL_PIN 3
#define I2C_TIMEOUT 100
#include "Arduino.h"
#include <SoftWire.h>
/////////////////////////HEADER////////////////////////////////////////////////////////////////////
#ifndef AS5600_h
#define AS5600_h
class AS5600
  //Code not important (cut bc it exceeded character limit)//////////////////////////////////
#endif
///////////////////////////SOURCE//////////////////////////////////////////////////////////////
SoftWire Wire = SoftWire();
AS5600::AS5600() {
  Wire.begin();
//*Code cut again here (not important)///////////////////////////////////////////////////////////////////////
 * Function: _getRegister
 *   register1: register address
 *   returns: the value within a register.
uint8_t AS5600::_getRegister(byte register1) {
  uint8_t _b=0;
  Wire.beginTransmission(_AS5600Address);
  Wire.write(register1);
  Wire.endTransmission();
  Wire.requestFrom(_AS5600Address, 1);
  while (Wire.available() == 0) { }
  _b = Wire.read();
  return _b;
 * Function: _getRegisters2
 *   registerMSB: register address of Most Significant Byte (MMSB)
 *   registerLSB: register address of Least Significant Byte (MMSB)
 *   returns: the value of the 16 bit number stored in registerMSB and registerLSB.
uint16_t AS5600::_getRegisters2(byte registerMSB, byte registerLSB) {
  uint16_t _hi=0, _lo=0;
  _hi = _getRegister(registerMSB);
  _lo = _getRegister(registerLSB);
  return (_hi<<8) | (_lo);
 * Function: _writeRegister
 *   registerAddress: register address to write to
 *   value: value to write to register at registerAddress
 *   returns: void
void AS5600::_writeRegister(byte registerAddress, byte value) {
  Wire.write((uint8_t)registerAddress); //module function register address
  Wire.write((uint8_t)value); //data bytes
AS5600 encoder;
long revolutions = 0;   // number of revolutions the encoder has made
double position = 0;    // the calculated value the encoder is at
double output;          // raw value from AS5600
long lastOutput;        // last output from AS5600
  output = encoder.getPosition();
  lastOutput = output;
  position = output;
  output = encoder.getPosition();           // get the raw value of the encoder
  if ((lastOutput - output) > 2047 )        // check if a full rotation has been made
    revolutions++;
  if ((lastOutput - output) < -2047 )
    revolutions--;
  position = revolutions * 4096 + output;   // calculate the position the the encoder is at based off of the number of revolutions
  Serial.println(position);
  lastOutput = output;                      // save the last raw value for the next loop
See My Reply #3 in this Thread.
Well, if you are using the Arduino IDE there is an arrow up right, press there, press new tab and just name it like file.h or file.cpp.
You could look at my detailed tutorial on How to Write Your Own Arduino Libraries
That will take you through step by step moving your code into separate files.
