Hello, can someone help me to create a PPM class for the Arduino nano matter?
At the moment i am working arround using the Tempsensor class for sending the PPM
Like 100 ppm is showing me 1 Grad Celsius.
Matter temperature sensor example
The example shows how to create a temperature sensor with the Arduino Matter API.
The example creates a Matter temperature sensor device and publishes the current CPU temperature through it.
The device has to be commissioned to a Matter hub first.
Compatible boards:
- Arduino Nano Matter
- SparkFun Thing Plus MGM240P
- xG24 Explorer Kit
- xG24 Dev Kit
- Seeed Studio XIAO MG24 (Sense)
Author: Tamas Jozsi (Silicon Labs)
#include <Matter.h>
#include <MatterTemperature.h>
#include <SparkFun_SGP40_Arduino_Library.h>
SGP40 sgp40_sensor;
MatterTemperature matter_temp_sensor;
Matter.begin();
pinMode(BTN_BUILTIN, INPUT_PULLUP);
pinMode(LEDR, OUTPUT);
digitalWrite(LEDR, HIGH);
matter_temp_sensor.begin();
Serial.println("Matter temperature sensor");
if (!Matter.isDeviceCommissioned()) {
Serial.println("Matter device is not commissioned");
Serial.println("Commission it to your Matter hub with the manual pairing code or QR code");
Serial.printf("Manual pairing code: %s\n", Matter.getManualPairingCode().c_str());
Serial.printf("QR code URL: %s\n", Matter.getOnboardingQRCodeUrl().c_str());
while (!Matter.isDeviceCommissioned()) {
delay(200);
decommission_handler();
Serial.println("Waiting for Thread network...");
while (!Matter.isDeviceThreadConnected()) {
delay(200);
Serial.println("Connected to Thread network");
Serial.println("Waiting for Matter device discovery...");
while (!matter_temp_sensor.is_online()) {
delay(200);
Serial.println("Matter device is now online");
// Initialize I2C
Wire.begin();
// Initialize sensor
Serial.println("SGP40 sensor initializing...");
if (!sgp40_sensor.begin()) {
Serial.println("SGP40 not detected");
Serial.println("Check connections and press the reset button to reinitialize");
while (1) ; // freezing
Serial.println("SGP40 sensor initialize done");
int current_voc = sgp40_sensor.getVOCindex();
matter_temp_sensor.set_measured_value_raw(current_voc);
Serial.printf("Current CPU VOC: %.02f C\n", current_voc);
delay(2000);
void decommission_handler() {
if (digitalRead(BTN_BUILTIN) == LOW) { //Push button pressed
// measures time pressed
int startTime = millis();
while (digitalRead(BTN_BUILTIN) == LOW) {
//delay(50);
int elapsedTime = (millis() - startTime) / 1000.0;
if (elapsedTime > 10) {
Serial.printf("Decommissioning!\n");
for (int i = 0; i < 10; i++) {
digitalWrite(LEDR, !(digitalRead(LEDR)));
delay(100);
Serial.println("Decommission done!");
digitalWrite(LEDR, LOW);
Serial.println("Matter device is commissioned-> Starting Decommission process");
nvm3_eraseAll(nvm3_defaultHandle); // Decomission command
digitalWrite(LED_BUILTIN, LOW);
Thanks
