Custom pinout definitions
Hi!
I use Arduino IDE to program my ESP32 module and I have a little problem:
I'd like to use the SD library with the pins 5, 18, 19, 21, but with "SD.begin()" I can only define the SS pin.
The ESP32's "pins_arduino.h" file contains the pin definitions, such as:
static const uint8_t TX = 1;
static const uint8_t RX = 3;
static const uint8_t SDA = 21;
static const uint8_t SCL = 22;
static const uint8_t SS    = 5;
static const uint8_t MOSI  = 23;
static const uint8_t MISO  = 19;
static const uint8_t SCK   = 18;
I have tried to modify the SPI pins in this file and it worked.
And I want to redefine these pins in my own "Config.h" or my own "pins_arduino.h" file (for one specific project) like this:
static const uint8_t SS    = 21;
static const uint8_t MOSI  = 19;
static const uint8_t MISO  =  5;
So I just copied the whole config file and made my own "Config.h" file, included it to my code and the results were like this:
redefinition of 'const uint8_t SCK'
I know I did something wrong, but I don't know how to do it. Is there even a way to do what I want?
The numbers in that file are the numbers of the pins that the functionality is hardwired to. How are you changing where the functionality is hardwired to?
So, both your config file and the default one are included. I can't see THAT as a good idea.
The ESP32 has a so called GPIO matrix so any function can be mapped to any pin.
How can I use my own config instead of the default one then?
The best way to proceed is to put your modified variant files (pins_arduino.h, etc.) in their own folder under the variants folder and then create your own board entry in the ESP32 hardware package's boards.txt that specifies the modified variant.
Details here:
