Hello,
I finished assembling my RP2040 based PCB and plugged it into my computer - nothing, even when I pressed the reboot button. Then I shorted the No-Fit resistor between QSPI_SS and 3V3 then RPI-RP2 (E:) shows up. At first I dragged and dropped MicroPython - Python for microcontrollers into the USB storage device and then it disconnected and disappeared. It did not show up as a com afterwards.
Next, I connected the board (again shorting the QSPI_SS and 3V3) to get the USB to show up and uploaded this arduino sketch:
Serial.println("I Work!");
The arduino IDE gave no errors and said:
Done Uploading
Sketch uses 89107 bytes (4%) of program storage space. Maximum is 2097152 bytes.
Global variables use 42784 bytes (15%) of dynamic memory, leaving 227552 bytes for local variables. Maximum is 270336 bytes.
Finally, I tried to upload a blink sketch to one of the header pins on my pcb (Pin 22) and using a voltmeter there was no sign of the code running.
Has anyone had this problem before and how would I fix it?
Thanks in advance.
