Hi, I have produced a custom board with ARM processor - SAMD21G18A. I wanted it to be programmable through Arduino, but instead of using EDBG chip for programming port I used FT232. Is it possible to use the same bootloader for my board as for Arduino Zero(programming port). I burned the bootloader with ATMEL ICE and I can see that it is in the flash, but I cannot upload any sketch. What could be the problem?
ERROR MESSAGE IN ARDUINO IDE:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Zero (Programming Port)"
Sketch uses 10128 bytes (3%) of program storage space. Maximum is 262144 bytes.
Open On-Chip Debugger 0.9.0-g932ec70 (2017-02-15-12:34)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
Error: unable to find CMSIS-DAP device
Error: No Valid JTAG Interface Configured.
I was also trying to upload the sketch using ATMEL ICE but although there are no errors in Arduino IDE, the board does not respond.
IN SHORT: Is it possible to program Arduino Zero with FTDI chip in Arduino IDE? or Is it possible to program Arduino Zero with ATMEL ICE in Arduino IDE?
