Custom variable width (coming from Verilog)
Hey guys,
I just finished a class in school that focused on FPGAs and hardware design.
I'm now having some trouble with how relatively inefficient the Arduino programming language is. I know it's designed this way for simplicity, but I'm ready to work more directly with the hardware.
Right now I want to declare a 24-bit variable, but i'm unsure how to do this.
More specifically, I want a 2-D array, with "X" number of 24-bit elements, each element holding three 8-bit values.
Also, any resources/links that I should read about lower level access would be appreciated!
You can define a three byte struct, but no arithmetic types.
I must've missed that particular class.
Panici:
typedef unsigned char bytes[3] twentyfourbitvalue;
twentyfourbitvalue myArray[rows][columns];
How hard was that?
