Custom voltage of output
Hello Arduino-ers,
This may be the wrong forum, if it it please correct me.
I am trying to work with LEGO components from the Arduino. I have found this explanation of the LEGO Mindstorms connector cables - and it says that one of the wires inside the cable needs to be connected to a 4.3 volt power source.
From what I know of Arduino, the regular power pins are 5V and 3.3V. Is there a way I could get a 4.3 volt output, whether in the Arduino language (ideal) or through hardware connected to the Arduino?
Thanks!
4.3v is a strange value to use. I suggest checking genuine Lego documentation to verify it.
If you really need it then you could use an LM117 variable voltage regulator to produce it. I don't know if there is enough headroom between 5v and 4.3v for it to work from the Arduino's 5v pin. You might need to feed 6v (or more) to the LM117.
...R
