Customizing OptiBoot, Almost compiling [Solved]
Well folks,
I am burning my fingers. @westfw has been giving me guidance but, I need some more help. At wesftw direction, I have installed WinAvr2010, and used it to compile optiboot.c, well almost. I added another procedure to support inplace self reprogramming, but the compiler is saying my procedure is defined but unused(.o generation), then in the next pass of avr-gcc (elf generation) It spits out undefined reference.
Here is the error from console:
C:\Users\user\Documents\GitHub\optiboot\optiboot\bootloaders\optiboot>make Targe
tV2
avr-gcc (WinAVR 20100110) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
process_begin: CreateProcess(NULL, bash baudcheck.tmp.sh, ...) failed.
make (e=2): The system cannot find the file specified.
make: [baudcheck] Error 2 (ignored)
avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=atmega2560 -DF_CPU=1600
0000L  -DBAUD_RATE=115200 -DLED_START_FLASHES=3      -DBIGBOOT -DDOSELF    -c -o
 optiboot.o optiboot.c
optiboot.c:305:6: warning: #warning BAUD_RATE error greater than 2%
optiboot.c: In function 'do_self':
optiboot.c:1100: warning: cast from pointer to integer of different size
optiboot.c:1101: warning: cast from pointer to integer of different size
optiboot.c:1112: warning: cast from pointer to integer of different size
optiboot.c:1113: warning: cast from pointer to integer of different size
optiboot.c:1128: warning: cast from pointer to integer of different size
optiboot.c: At top level:
optiboot.c:1083: warning: 'do_self' defined but not used
0000L  -DBAUD_RATE=115200 -DLED_START_FLASHES=3      -DBIGBOOT -DDOSELF  -Wl,--s
ection-start=.text=0x3fc00 -Wl,--section-start=.version=0x3fffe -Wl,--relax -nos
tartfiles -nostdlib -o optiboot_TargetV2.elf optiboot.o -lc
optiboot.o: In function `pre_main':
C:\Users\user\Documents\GitHub\optiboot\optiboot\bootloaders\optiboot/optiboot.c
:447: undefined reference to `do_self'
:447: relocation truncated to fit: R_AVR_13_PCREL against undefined symbol `do_s
elf'
make: *** [optiboot_TargetV2.elf] Error 1
rm optiboot.o
I am attaching my modified optiboot, and the MakeCustom
Chuck.
optiboot.c (40.5 KB)
Makefile.Custom.txt (1.11 KB)
Have you successfully compiled unmodified Optiboot?
That's what I would try first.
dmjlambert:
Yes, I can compile optiboot. Here is an example compiling the bootloader for Lilypad.
C:\Users\user\Documents\GitHub\optiboot\optiboot\bootloaders\optiboot>make lilyp
ad
make atmega168 AVR_FREQ=8000000L LED_START_FLASHES=3
make[1]: Entering directory `C:/Users/user/Documents/GitHub/optiboot/optiboot/bo
otloaders/optiboot'
make[1]: [baudcheck] Error 2 (ignored)
avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=atmega168 -DF_CPU=80000
00L  -DBAUD_RATE=115200 -DLED_START_FLASHES=3        -c -o optiboot.o optiboot.c
optiboot.c:298:6: warning: #warning BAUD_RATE error greater than -2%
00L  -DBAUD_RATE=115200 -DLED_START_FLASHES=3      -Wl,--section-start=.text=0x3
e00 -Wl,--section-start=.version=0x3ffe -Wl,--relax -nostartfiles -nostdlib -o o
ptiboot_atmega168.elf optiboot.o -lc
avr-size optiboot_atmega168.elf
   text    data     bss     dec     hex filename
    492       0       0     492     1ec optiboot_atmega168.elf
avr-objcopy -j .text -j .data -j .version --set-section-flags .version=alloc,loa
d -O ihex optiboot_atmega168.elf optiboot_atmega168.hex
avr-objdump -h -S optiboot_atmega168.elf > optiboot_atmega168.lst
rm optiboot.o optiboot_atmega168.elf
make[1]: Leaving directory `C:/Users/user/Documents/GitHub/optiboot/optiboot/boo
tloaders/optiboot'
mv optiboot_atmega168.hex optiboot_lilypad.hex
mv optiboot_atmega168.lst optiboot_lilypad.lst
any Ideas?
Chuck.
I just got it to compile, I had to add a dummy call after the appStart(ch); in Main(). It'll never actually reach it, but the compiler doesn't know!
Now to actually see if it works! :slight_smile: :smiling_imp: :smiling_imp: :stuck_out_tongue_closed_eyes:
I'm going to have to increase the boot size, .text is 1334 bytes
tV2
optiboot.c:1105: warning: cast from pointer to integer of different size
optiboot.c:1106: warning: cast from pointer to integer of different size
optiboot.c:1117: warning: cast from pointer to integer of different size
optiboot.c:1118: warning: cast from pointer to integer of different size
optiboot.c:1133: warning: cast from pointer to integer of different size
ection-start=.text=0x3E000 -Wl,--section-start=.version=0x3fffe -Wl,--relax -nos
avr-size optiboot_TargetV2.elf
   1334       0       0    1334     536 optiboot_TargetV2.elf
d -O ihex optiboot_TargetV2.elf optiboot_TargetV2.hex
avr-objdump -h -S optiboot_TargetV2.elf > optiboot_TargetV2.lst
rm optiboot.o optiboot_TargetV2.elf
Chuck
A bit above my skill level. Could you describe what the inplace self reprogramming is supposed to do?
dmjlambert:
I have a network(RS485) of custom Mega2560 boards controlling equipment. It is a hassle to carry a laptop with an AVRISP to each one to download software updates. Each of these boards have SD cards and SPI Flash onboard.
This compilation success will allow remote reprogramming. Since I have been able to compile a custom bootloader. I will be able to use the SPM (Self Programming) feature of AVR processors. With my re-programming routine I can create application code that can successfully overwrite itself with new code.
The code I added to the bootloader will use an external FLASH chip as a source for the updated application code. I will be able to send a software update to each of my devices. The devices will store the software update in an external SPI Flash chip, a Winbond W25Q64F (8MB 8pin SPI Flash). Once the download is received and verified, the address of the image is passed to my re-programming routine. This routine re-flashes the Mega2560 IC. As long as the new code still supports the network and SPI Flash, I will be able to change the program in my custom Mega2560's without leaving my desk! :smiley:
The application code will also have the ability to read the SDcard. It can transfer updated code from the SDcard to the SPI Flash, then initiate the re-programming routine.
Life is looking good!
Chuck.
