Customizing wave shield code
So I've been trying to put together the project from this website that lights up an LED when there is unread mail in gmail:
http://blog.tinyenormous.com/2008/11/25/gmail-notifier-project-for-dummies/
I've gotten it to run as is, but now I'd like to incorporate this wave shield (Audio Shield for Arduino) so that instead of activating the LED, it activates audio from the wave shield. The code I'm using in arduino is below, and I've tried tampering with it but I'm not sure where to go from here. If you have any advice on how to alter this code or any general recommendations, it would really help. Thanks.
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
int outPin= 12; //Ouput connected to digital pin 12
int mail= LOW;// Is there new mail?
int val; // Value read from the serial port
int incomingByte;
// Function definitions (we define them here, but the code is below)
void lsR(FatReader &d);
void play(FatReader &dir);
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
  putstring_nl("\nWave test!");  // say we woke up!
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(outPin, OUTPUT);// sets the digital pin as output
  digitalWrite(outPin, HIGH);
  Serial.begin (9600);
  Serial.flush();
  mail= HIGH; //start off with lights out
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Files found:");
  dirLevel = 0;
  // Print out all of the files in all the directories.
  lsR(root);
//////////////////////////////////// LOOP
  root.rewind();
  play(root);
/////////////////////////////////// HELPERS
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * print dir_t name field. The output is 8.3 format, so like SOUND.WAV or FILENAME.DAT
void printName(dir_t &dir)
  for (uint8_t i = 0; i < 11; i++) {     // 8.3 format has 8+3 = 11 letters in it
    if (dir.name[i] == ' ')
        continue;         // dont print any spaces in the name
    if (i == 8)
        Serial.print('.');           // after the 8th letter, place a dot
    Serial.print(dir.name[i]);      // print the n'th digit
  if (DIR_IS_SUBDIR(dir))
    Serial.print('/');       // directories get a / at the end
 * list recursively - possible stack overflow if subdirectories too nested
  int8_t r;                     // indicates the level of recursion
  while ((r = d.readDir(dirBuf)) > 0) {     // read the next file in the directory
    // skip subdirs . and ..
    if (dirBuf.name[0] == '.')
      continue;
    for (uint8_t i = 0; i < dirLevel; i++)
      Serial.print(' ');        // this is for prettyprinting, put spaces in front
    printName(dirBuf);          // print the name of the file we just found
    Serial.println();           // and a new line
    if (DIR_IS_SUBDIR(dirBuf)) {   // we will recurse on any direcory
      FatReader s;                 // make a new directory object to hold information
      dirLevel += 2;               // indent 2 spaces for future prints
      if (s.open(vol, dirBuf))
        lsR(s);                    // list all the files in this directory now!
      dirLevel -=2;                // remove the extra indentation
  sdErrorCheck();                  // are we doign OK?
 * play recursively - possible stack overflow if subdirectories too nested
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // skip . and .. directories
      continue;
    Serial.println();            // clear out a new line
    if (!file.open(vol, dirBuf)) {       // open the file in the directory
      Serial.println("file.open failed");  // something went wrong :(
      while(1);                            // halt
    if (file.isDir()) {                    // check if we opened a new directory
      putstring("Subdir: ");
      printName(dirBuf);
      dirLevel += 2;                       // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing "); printName(dirBuf);       // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
      } else if (Serial.available())
        val=Serial.read();
        Serial.println(val, BYTE);
        wave.play();                       // make some noise!
        if (val==110)//
          mail= HIGH;
        else if (val == 109)
          mail = LOW;
       digitalWrite (outPin, mail);
        while (wave.isplaying) {           // playing occurs in interrupts, so we print dots in realtime
          putstring(".");
          delay(100);
        sdErrorCheck();                    // everything OK?
//        if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
I have code for a wave shield project that will lead you in the right direction. It is posted here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1272995447/0#0
When an IR sensor is activated it will play a song. I have several songs stored on the card, it will only play one each time. Once all the songs have eventually been played it starts back at the beginning.
My code uses the AF Wave library.
You could use the code as is to play a different song or message each time you get email. Or, you could just put one song on the card and it will play that same one every time.
I'm not sure how exactly, but there should be a way to modify the code to activate a different song or verbal message depending on who has sent you the mail.
