Cut here for exception decoder
Hello guys, I hope you're doing well. When I add the ADS1115 code to my code, it shows me this error. What can I do with the ADS1115 code not working properly? Without the ADS1115 code, it works properly.
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Adafruit_ADS1X15.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
Adafruit_ADS1115 ads0;
Adafruit_ADS1115 ads1;
Adafruit_ADS1115 ads2;
Adafruit_ADS1115 ads3;
#include <DHT.h>
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "";  // type your wifi name
char pass[] = "";  // type your wifi password
BlynkTimer timer;
#define DHTPIN D5 //Connect Out pin to D2 in NODE MCU
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
int offset = 20;
void sendSensor()
  float hum = dht.readHumidity();
  float temp = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(hum) || isnan(temp)) {
    Serial.println("Failed to read DHT sensor!");
    return;
  int16_t adc0, adc1, adc2, adc3;
  adc0 = ads0.readADC_SingleEnded(0);
  int volt = adc0;
  double voltage = map(volt,0,1023, 0, 2500) +offset;
  voltage /=100;
//  float heat;
//  heat = ads0.readADC_SingleEnded(1);
//  heat = heat*0.48828125;
//  float current = 0;
//  for(int i = 0; i< 1000; i++){
//    current = current +(.100 * ads0.readADC_SingleEnded(2) -25) / 100;
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
    Blynk.virtualWrite(V0, temp);
    Blynk.virtualWrite(V1, hum);
    Blynk.virtualWrite(V2, voltage);
//    Blynk.virtualWrite(V3, current);
//    Blynk.virtualWrite(V4, heat);
    Serial.print("Temperature: ");
    Serial.print(temp);
    Serial.print("    Humidity: ");
    Serial.print(hum);
    Serial.print("    Voltage: ");
    Serial.print(voltage);
    Serial.print(" V");
//    Serial.print("    Heat: ");
//    Serial.print(heat);
//    Serial.print("    Current: ");
//    Serial.print(current);
//    Serial.println(" A");
  // Turn on the blacklight and print a message.
    lcd.setCursor(0, 0);
    lcd.print("Te:");
    lcd.print((float)temp);
    lcd.print(" H:");
    lcd.print((float)hum);
    lcd.setCursor(0, 1);
    lcd.print("Vo:");
    lcd.print((float)voltage);
//    lcd.print("  C:");
//    lcd.print((float)current);
//    lcd.setCursor(1, 1);
  Wire.begin();
  lcd.begin();
  lcd.backlight();
  ads0.begin();
  ads1.begin(0x49);
  ads2.begin(0x4a);
  ads3.begin(0x4b);
  Blynk.begin(auth, ssid, pass);
  dht.begin();
  timer.setInterval(1000L, sendSensor);
  Blynk.run();
  timer.run();
![llll|390x500](upload://mU9MHZHdMi2ZBOd3i5dMBHMpfT2.png)
Welcome to the forum
Please post the full text of the error message copied from the IDE using the "Copy error message" button and use code tags when you post it
Which Arduino and which version of the IDE are you using ?
What model ESP8266 are you using? I tried "Generic ESP8266 Module" and got some errors indicating that was the wrong guess. I switched to "NodeMCU 1.0 (ESP-12E Module)" and that worked a little better.
What "LiquidCrystal_I2C" library are you using? The one I have installed doesn't seem to be compatible with the one you need.
Arduino: 1.8.19 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
WARNING: library LiquidCrystal_I2C claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
In file included from /Users/john/Documents/Arduino/libraries/Blynk/src/BlynkWidgets.h:14,
                 from /Users/john/Documents/Arduino/libraries/Blynk/src/BlynkSimpleEsp8266.h:107,
                 from /Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino:6:
/Users/john/Documents/Arduino/libraries/Blynk/src/WidgetTimeInput.h: In constructor 'TimeInputParam::TimeInputParam(const BlynkParam&)':
/Users/john/Documents/Arduino/libraries/Blynk/src/WidgetTimeInput.h:45:43: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
   45 |             mStart = BlynkTime(it.asLong());
In file included from /Users/john/Documents/Arduino/libraries/Blynk/src/WidgetTimeInput.h:15,
/Users/john/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkDateTime.h:65:5: note: because 'BlynkTime' has user-provided 'BlynkTime::BlynkTime(const BlynkTime&)'
   65 |     BlynkTime(const BlynkTime& t) : mTime(t.mTime) {}
/Users/john/Documents/Arduino/libraries/Blynk/src/WidgetTimeInput.h:59:42: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
   59 |             mStop = BlynkTime(it.asLong());
/Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino: In function 'void sendSensor()':
/Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino:45:17: warning: unused variable 'adc1' [-Wunused-variable]
   45 |   int16_t adc0, adc1, adc2, adc3;
/Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino:45:23: warning: unused variable 'adc2' [-Wunused-variable]
/Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino:45:29: warning: unused variable 'adc3' [-Wunused-variable]
/Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino: In function 'void setup()':
sketch_sep26a:106:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
  106 |   lcd.begin();
In file included from /Users/john/Documents/Arduino/sketch_sep26a/sketch_sep26a.ino:10:
/Users/john/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate: 'void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)'
   58 |   void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
/Users/john/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note:   candidate expects 3 arguments, 0 provided
exit status 1
option enabled in File -> Preferences.
