Hello all,
I've spent the last few months creating a portable autosampler meant to collect a series of water samples every 15 minutes over the course of 24 hours, and post data to freeboard.io and send SMS alerts to the operator. I thought I had thought of everything, but yesterday I got the idea to add a water sensor under the tubing for the peristaltic pump if a leak happens which then blinks an LED and a buzzer until it is dry again. Obviously, this wont work as a fail safe.
Is there a way to make all pins on the ESP32 go low when the sensor detects water? or is there a way to shut off power to the esp32 when water is detected until it is reset? Would I need a power relay?
the power source is a 12 Volt battery which is regulated to 12VDC to power the pump and 4.5 VDC to energize the esp32. Is there an example of power from an arduino/esp32 energizing a relay to allow 12vdc input with some sort of trigger that deenergizes the pin of the microcontroller which provides power to the relay? I'll post the part of the code which deals with the water sensor, as well as the full code (its pretty long and could use streamlining)
#define SIGNAL_PIN 36 // ESP32 pin GIOP36 (ADC0) connected to sensor's signal pin
#define samplingRate2 3000UL // the time between sensor readouts
unsigned long counter2 = 0;
int value = 0; // variable to store the sensor value
const int LeakLED = 19;
unsigned long currentMillis; // millis() of the current loop.
pinMode(LeakLED, OUTPUT) ;
currentMillis = millis();
value = analogRead(SIGNAL_PIN); // read the analog value from sensor
if (currentMillis - counter2 > samplingRate2) {
Serial.print("The water sensor value: ");
Serial.println(value);
counter2 = millis();
if (value > 1) {
digitalWrite(LeakLED, HIGH);
digitalWrite(LeakLED, LOW);
Serial.println("LEAK DETECTED!");
else {
LiquidCrystal_I2C lcd(0x3F, 20, 4);
#include <Wire.h>
#include <OneWireNg.h>
#include <DallasTemperature.h>
#include <ezButton.h>
#include <Adafruit_ADS1X15.h>
#include <MultiMap.h>
#define ONE_WIRE_BUS 4
/***********************************GPRS/SMS STUFF ****************************************/
#include "Adafruit_FONA.h" // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code
#include <HardwareSerial.h>
// For SIM7000 shield
#define FONA_PWRKEY 18
#define FONA_RST 5
#define FONA_TX 16 // ESP32 hardware serial RX2 (GPIO16)
#define FONA_RX 17 // ESP32 hardware serial TX2 (GPIO17)
#define SIMCOM_7000
#define PROTOCOL_HTTP_GET // Generic
#define LED 2
HardwareSerial fonaSS(1);
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();
#define samplingRate 300000UL // The time in between posts, in millis
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
char imei[16] = {0}; // Use this for device ID
char replybuffer[255]; // Large buffer for replies
uint8_t type;
unsigned long counter = 0;
/**** BOOL VARIABLES FOR SMS ALERTS ****/
bool bat = false;
bool opened = false;
bool cold = false;
char volBuff[12];
char tempBuff[12];
char batBuff[12];
char URL[300]; // Make sure this is long enough for your request URL
char body[200]; // Only need this is you're doing an HTTP POST request
/**** FLOAT SWITCH ****/
const int buttonPin = 33;
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
const int FloatSwitchLED = 15;
const int ResetLED = 2;
const char * phone_number = "+18326831676"; // Include country code, only numbe
/***** SMS ALERTS ********/
const char * text_message1 = " mL FULL!"; // Change to suit your needs
const char * text_messageV = volBuff;
const char * text_message3 = " % BATTERY LOW!";
const char * text_messageB = batBuff;
const char * text_message2 = "*F FREEZING!"; // Change to suit your needs
const char * text_messageF = tempBuff;
volatile int count; //This integer needs to be set as volatile to ensure it updates correctly during the interrupt process.
float tLimit = 30.0; //the amount of liquid in mL that the pump is supposed to collect during pump cycle
int Threshold; //the threshold for amount of liquid collected before pump returns to OffState
bool ThresholdLimit = false; // flag for Threshold
Adafruit_ADS1115 ads;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
unsigned long startMillis; // Keeps track of millis() when the pumping cycle starts.
// constants for Arduino IO-Pins with SELF-explaining names
const byte samplingBtnPin = 12;
const byte primeBtnPin = 13;
const byte purgeBtnPin = 14;
const byte resetBtnPin = 32;
ezButton button1(12); // create ezButton object that attach to pin 12;
ezButton button2(32); // create ezButton object that attach to pin 12;
const byte DRV8876_IN1_PIN = 26;
const byte DRV8876_IN2_PIN = 27;
int flowPin = 25; //This is the input pin on the Arduino, flow switch
float calibrationFactor = 121; //calibration factor for sampling is 150, need to make if else statement for it
float tempC;
float tempF;
int percent;
/**************************************************** Battery stuf **************************************************/
int R1 = 27, R2 = 10; // 10k and 27k ; the resistor ratio
float dividerRatio; // pre-calculate in setup
float calFactor = 1.01; // calibrate if needed
int in[] = {
10000, 12000, 12500, 12800, 12900, 13000, 13100, 13200, 13300, 13400, 13600, 14600, 14900
}; // [13] IN holds the mV inputs
int out [] = {
0, 9, 14, 17, 20, 30, 40, 70, 90, 99, 100, 110, 120
}; // [13] OUT holds the percentage outputs
float bLimit = 20; // the lower limit of the percentage, if battery percent falls below 20, lowbatsMs is sent
int Val; // holds input and output values for multimap
float vLimit = 32.0;
volatile byte pulseCount; // counts the pulses of flow sensor
float flowRate;
unsigned int flowMilliLitres; //totaltotalMilliLitres used for the interrupts
unsigned long totalMilliLitres;
unsigned long oldTime;
unsigned long cloopTime; // to count pulses per second
unsigned long vol; //vol tracks total volume throughout loop
// constants for the states with SELF-explaining names
const byte OffState = 0;
const byte PumpState = 1;
const byte PausingState = 2;
const byte ReverseState = 3;
const byte RestState = 4;
const byte FullState = 5;
const byte PurgeState = 6;
byte state;
#define pressed HIGH
#define released LOW
#define closed HIGH
#define open LOW
// bool primeBtnPinHasBeenPressed = true;
bool purgeBtnPinHasBeenPressed = false;
void pulseCounter()
// Increment the pulse counter
pulseCount++;
lcd.begin();
button1.setDebounceTime(50); // set debounce time to 50 milliseconds
button2.setDebounceTime(50); // set debounce time to 50 milliseconds
Serial.println("ESP32 PUMP");
pinMode(primeBtnPin, INPUT_PULLUP); // pinMode(5, INPUT);
pinMode(purgeBtnPin, INPUT_PULLUP); // pinMode(6, INPUT);
pinMode(samplingBtnPin, INPUT_PULLUP); // pinMode(7, INPUT);
pinMode(resetBtnPin , INPUT_PULLUP);
pinMode(FloatSwitchLED, OUTPUT);
pinMode(ResetLED, OUTPUT);
pinMode(DRV8876_IN1_PIN, OUTPUT); // pinMode(A0, OUTPUT);
pinMode(DRV8876_IN2_PIN, OUTPUT); // pinMode(A1, OUTPUT);
pinMode(flowPin, INPUT_PULLUP);
digitalWrite(flowPin, LOW);
Threshold = 3400.0; //Threshold limit
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0.0;
totalMilliLitres = 0;
vol = 0;
cloopTime = currentMillis;
attachInterrupt(digitalPinToInterrupt(flowPin), pulseCounter, FALLING);
dividerRatio = (R1 + R2) / R1;
ads.setGain(GAIN_ONE);
ads.begin();
/************************************************GRPS/SMS STUFF*************************************************/
#ifdef LED
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
#endif
pinMode(FONA_RST, OUTPUT);
digitalWrite(FONA_RST, HIGH); // Default state
pinMode(FONA_PWRKEY, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
powerOn(true); // Power on the module
moduleSetup(); // Establish first-time serial comm and print IMEI
fona.setFunctionality(1); // AT+CFUN=1
fona.setNetworkSettings(F("hologram")); // For Hologram SIM card, change appropriately
// Perform first-time GPS/GPRS setup if the shield is going to remain on,
// otherwise these won't be enabled in loop() and it won't work!
#ifndef turnOffShield
#if !defined(SIMCOM_3G) && !defined(SIMCOM_7500) && !defined(SIMCOM_7600)
// Disable GPRS just to make sure it was actually off so that we can turn it on
if (!fona.enableGPRS(false)) Serial.println(F("Failed to disable GPRS!"));
// Turn on GPRS
while (!fona.enableGPRS(true) && (millis() < 10000)) {
Serial.println(F("Failed to enable GPRS, retrying..."));
delay(2000); // Retry every 2s
Serial.println(F("Enabled GPRS!"));
#endif
#endif
/************************************************GRPS/SMS STUFF end*********************************************/
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
button1.loop(); // MUST call the loop() function first
button2.loop(); // MUST call the loop() function first
int btn1State = button1.getState();
int btn2State = button2.getState();
// if (digitalRead(primeBtnPin) == released) primeBtnPinHasBeenPressed = false;
if (digitalRead(purgeBtnPin) == released) purgeBtnPinHasBeenPressed = true;
currentMillis = millis(); // Get the current value of millis().
buttonState = digitalRead(buttonPin);
if (digitalRead(samplingBtnPin) == released)
if (state > OffState) // Are we already in a pumping cycle?
state = OffState;
state = PumpState;
// delay(200); // Small delay to debounce the button.
int adc0 = ads.readADC_SingleEnded(0);
float battVoltage = ads.computeVolts(adc0) * dividerRatio * calFactor;
float battVolt = battVoltage * 3.7;
int battmV = (battVolt * 1000) + 30;
Val = battmV;
// int percent;
percent = multiMap(Val, in, out, 13);
// delay(1000);
dtostrf(percent, 1, 2, batBuff);
dtostrf(tempF, 1, 2, tempBuff);
dtostrf(vol, 1, 2, volBuff);
sensors.requestTemperatures(); // Send the command to get temperatures
// Serial.println("DONE");
printTemperature(insideThermometer); // Use a simple function to print out the data
tempC = sensors.getTempCByIndex(0);
tempF = (tempC * 1.8) + 32;
lcd.setCursor(0, 3);
lcd.print("B%");
lcd.setCursor(3, 3);
lcd.print(percent);
lcd.setCursor(7, 3);
lcd.print("TEMP:");
lcd.setCursor(13, 3);
lcd.print(tempF);
if (percent < 100) { //if battery percent falls below 100, erase the third digit
lcd.setCursor(5, 3);
lcd.print(" ");
if (percent < 10) {
lcd.setCursor(4, 3); //if battery falls below 10 percent, erase second and third digit
lcd.print(" ");
if (digitalRead(buttonPin) == HIGH) {
digitalWrite(FloatSwitchLED, LOW);
else {
digitalWrite(FloatSwitchLED, HIGH);
/********************************* read sensor stats and print on serial monitor *************************/
Serial.println("-----------------------------------------------------------");
Serial.print("Batt Volts: "); Serial.print(battVoltage, 3); Serial.print(" "); Serial.print("AIN0: "); Serial.print(adc0 ); Serial.print(" "); Serial.print(" BatVolt: "); Serial.println(battVolt, 3);
Serial.print("Battery mV: "); Serial.print(battmV); Serial.print(" "); Serial.print("Battery level [%]: "); Serial.println(percent);
Serial.println(sensors.getResolution(insideThermometer), DEC);
Serial.print("Temp C: "); Serial.print(tempC); Serial.print(" "); Serial.print(" Temp F: "); Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
Serial.print("FLOW ML: "); Serial.println(flowMilliLitres);
if (ThresholdLimit == true) {
Serial.print("THRESHOLD REACHED"); Serial.println(Threshold);
} else
Serial.println("THRESHOLD NOT REACHED");
Serial.println("FLOAT SWITCH OPEN!");
/****** flow rate math ********/
if (currentMillis >= (cloopTime + 1000))
if (pulseCount != 0) {
flowRate = (pulseCount / calibrationFactor);
//oldTime = millis();
flowMilliLitres = (flowRate / 60) * 1000;
totalMilliLitres += flowMilliLitres;
vol += flowMilliLitres;
Serial.print(flowRate); Serial.println(" :L/min");
Serial.print(totalMilliLitres); Serial.println(" :mL");
lcd.setCursor(0, 1);
lcd.print(flowRate);
lcd.setCursor(5, 1);
lcd.print(":L/min");
lcd.setCursor(0, 2);
lcd.print(vol);
lcd.setCursor(6, 2);
lcd.print(": mL");
pulseCount = 0;
else {
Serial.print(vol); Serial.println(" :mL");
lcd.setCursor(6, 1);
lcd.print(vol);
lcd.print(": mL");
flowRate = 0;
///////////Leak Detection/////////////
if (value > 1) {
else {
switch (state) // Check which state we are in.
case OffState:
// manualMode();
if (digitalRead(primeBtnPin) == pressed) {
pumpOff();
else {
manualMode();
if (purgeBtnPinHasBeenPressed = true) {
state = PurgeState;
else {
if (digitalRead(resetBtnPin) == released) { // keep this button in OffState case so that if accidently pressed it wont hurt anything
resetData();
digitalWrite(ResetLED, HIGH);
else {
digitalWrite(ResetLED, LOW);
startMillis = currentMillis; // Keep resetting the start time of the pumping sequence.
pumpOff();
case PurgeState:
if (digitalRead(purgeBtnPin) == pressed)
state = OffState;
manualPurge();
case PumpState:
if (totalMilliLitres > vLimit || currentMillis - startMillis > 106000) /// did we collect XmL? if not, go to next stage after X millis
state = PausingState;
PumpForward();
case PausingState:
if (currentMillis - startMillis > 109000) // Have we been in this state too long?
state = ReverseState;
pumpOff();
Serial.println("PAUSE!");
lcd.setCursor(0, 0);
lcd.print("PAUSED! ");
case ReverseState:
if (currentMillis - startMillis > 209000) // Have we been in this state too long?
state = RestState;//state++;
PumpReverse();
case RestState:
if (currentMillis - startMillis > 600000) // has it been X minutes?
state = FullState;
startMillis = currentMillis; // Reset the start time of the pumping sequence.
totalMilliLitres = 0; //reset totalMilliLitres so it can start counting up from 0 again
pumpOff();
Serial.println("REST!");
lcd.print("RESTING!");
case FullState:
if (ThresholdLimit == true) { //|| (digitalRead(buttonPin) == HIGH))
state = OffState;
else {
Serial.println(state);
state = PumpState;
/***************************SMS ALERTS***************************************************/
if (buttonState == HIGH && lastButtonState == LOW || vol > 3100 && vol - flowMilliLitres <= 3100) {
opened = false;
ThresholdLimit = true;
lastButtonState = buttonState;
FullSMS ();
pumpOff();
lcd.print("FULL ");
if (tempF < tLimit && cold == false) {
ColdSMS ();
cold = true;
else if (tempF > tLimit + 2.0 && cold == true) {
cold = false;
if (percent < bLimit && bat == false) {
batSMS ();
bat = true;
/***************************SMS ALERTS END***************************************************/
/**************************** DATA POST TO DWEET *********************************************/
if (millis() - counter > samplingRate) {
PostData ();
counter = millis ();
void Full() {
lcd.setCursor (0, 0);
lcd.print("FULL");
digitalWrite(DRV8876_IN1_PIN, LOW);
digitalWrite(DRV8876_IN2_PIN, LOW);
void manualMode() {
digitalWrite(DRV8876_IN1_PIN, HIGH); // comment is obsolete code epxlains ITSELF Turn on the pump (forward).
// Serial.println("PUMPING!");
lcd.print("PUMPING!");
void manualPurge() {
digitalWrite(DRV8876_IN1_PIN, LOW); // comment is obsolete code epxlains ITSELF Turn on the pump (forward).
digitalWrite(DRV8876_IN2_PIN, HIGH);
lcd.print("PURGING!");
// senseful SUB-unit of code with a SELF-explaining name
void PumpForward() {
void resetData() {
flowRate = 0;
vol = 0;
flowMilliLitres = 0;
Serial.println("Data Reset");
lcd.print(vol);
lcd.setCursor(1, 2);
lcd.print(" ");
pulseCount = 0;
void PumpReverse() {
digitalWrite(DRV8876_IN1_PIN, LOW); // comment is obsolete code epxlains ITSELF Reverse the pump.
Serial.println("PURGING!");
void pumpOff()
lcd.print("PUMP OFF");
void printTemperature(DeviceAddress deviceAddress)
// method 1 - slower
//Serial.print("Temp C: ");
//Serial.print(sensors.getTempC(deviceAddress));
//Serial.print(" Temp F: ");
//Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
// method 2 - faster
float tempC = sensors.getTempC(deviceAddress);
if (tempC == DEVICE_DISCONNECTED_C)
Serial.println("Error: Could not read temperature data");
return;
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// Power on/off the module
void powerOn(bool state) {
if (state) {
Serial.println(F("Turning on SIM7000..."));
digitalWrite(FONA_PWRKEY, LOW);
delay(100); // Turn on module
digitalWrite(FONA_PWRKEY, HIGH);
delay(4500); // Give enough time for the module to boot up before communicating with it
else {
Serial.println(F("Turning off SIM7000..."));
fona.powerDown(); // Turn off module
void moduleSetup() {
// SIM7000 takes about 3s to turn on and SIM7500 takes about 15s
// Press Arduino reset button if the module is still turning on and the board doesn't find it.
// When the module is on it should communicate right after pressing reset
// Software serial:
fonaSS.begin(115200, SERIAL_8N1, FONA_TX, FONA_RX); // baud rate, protocol, ESP32 RX pin, ESP32 TX pin
Serial.println(F("Configuring to 9600 baud"));
fonaSS.println("AT+IPR=9600"); // Set baud rate
delay(500); // Short pause to let the command run
fonaSS.begin(9600, SERIAL_8N1, FONA_TX, FONA_RX); // Switch to 9600
if (! fona.begin(fonaSS)) {
Serial.println(F("Couldn't find FONA"));
// while (1); // Don't proceed if it couldn't find the device
// Hardware serial:
fonaSerial->begin(115200); // Default SIM7000 baud rate
if (! fona.begin(*fonaSerial)) {
DEBUG_PRINTLN(F("Couldn't find SIM7000"));
// The commented block of code below is an alternative that will find the module at 115200
// Then switch it to 9600 without having to wait for the module to turn on and manually
// press the reset button in order to establish communication. However, once the baud is set
// this method will be much slower.
fonaSerial->begin(115200); // Default LTE shield baud rate
fona.begin(*fonaSerial); // Don't use if statement because an OK reply could be sent incorrectly at 115200 baud
fona.setBaudrate(9600); // Set to 9600 baud
fonaSerial->begin(9600);
if (!fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find modem"));
while(1); // Don't proceed if it couldn't find the device
type = fona.type();
Serial.println(F("FONA is OK"));
Serial.print(F("Found "));
switch (type) {
case SIM800L:
Serial.println(F("SIM800L")); break;
case SIM800H:
Serial.println(F("SIM800H")); break;
case SIM808_V1:
Serial.println(F("SIM808 (v1)")); break;
case SIM808_V2:
Serial.println(F("SIM808 (v2)")); break;
case SIM5320A:
Serial.println(F("SIM5320A (American)")); break;
case SIM5320E:
Serial.println(F("SIM5320E (European)")); break;
case SIM7000:
Serial.println(F("SIM7000")); break;
case SIM7070:
Serial.println(F("SIM7070")); break;
case SIM7500:
Serial.println(F("SIM7500")); break;
case SIM7600:
Serial.println(F("SIM7600")); break;
default:
Serial.println(F("???")); break;
// Print module IMEI number.
uint8_t imeiLen = fona.getIMEI(imei);
if (imeiLen > 0) {
Serial.print("Module IMEI: "); Serial.println(imei);
bool netStatus() {
int n = fona.getNetworkStatus();
Serial.print(F("Network status ")); Serial.print(n); Serial.print(F(": "));
if (n == 0) Serial.println(F("Not registered"));
if (n == 1) Serial.println(F("Registered (home)"));
if (n == 2) Serial.println(F("Not registered (searching)"));
if (n == 3) Serial.println(F("Denied"));
if (n == 4) Serial.println(F("Unknown"));
if (n == 5) Serial.println(F("Registered roaming"));
if (!(n == 1 || n == 5)) false;
else return true;
void FullSMS () {
char message3[20];
strcpy(message3, volBuff);
strcat(message3, text_message1);
// powerOn(true); // Power on the module
// moduleSetup(); // Establish first-time serial comm and print IMEI
while (!netStatus() && (millis() < 30000)) {
Serial.println(F("Failed to connect to cell network, retrying..."));
Serial.println(F("Connected to cell network!"));
// Send a text to your phone!
if (!fona.sendSMS(phone_number, message3)) {
Serial.println(F("Failed to send text!"));
else {
Serial.println(F("Sent text alert!"));
void ColdSMS () {
char message[20];
strcpy(message, tempBuff);
strcat(message, text_message2);
if (!fona.sendSMS(phone_number, message)) {
else {
void batSMS () {
char message2[25];
strcpy(message2, batBuff);
strcat(message2, text_message3);
if (!fona.sendSMS(phone_number, message2)) {
else {
void PostData ()
// If the shield was already on, no need to re-enable
#if defined(turnOffShield) && !defined(SIMCOM_3G) && !defined(SIMCOM_7500) && !defined(SIMCOM_7600)
// Turn on GPRS
while (!fona.enableGPRS(true) && (millis() < 30000)) {
#endif
// Post something like temperature and battery level to the web API
// Construct URL and post the data to the web API
// Format the floating point numbers
// Also construct a combined, comma-separated location array
// (many platforms require this for dashboards, like Adafruit IO):
//sprintf(locBuff, "%s,%s,%s,%s", speedBuff, latBuff, longBuff, altBuff); // This could look like "10,33.123456,-85.123456,120.5"
// Construct the appropriate URL's and body, depending on request type
// In this example we use the IMEI as device ID
#ifdef PROTOCOL_HTTP_GET
// GET request
counter = 0; // This counts the number of failed attempts tries
#if defined(SIMCOM_3G) || defined(SIMCOM_7500) || defined(SIMCOM_7600)
// You can adjust the contents of the request if you don't need certain things like speed, altitude, etc.
sprintf(URL, "GET /dweet/for/%s?temp=%s&bat=%s&vol=%s HTTP/1.1\r\nHost: dweet.io\r\n\r\n",
imei, tempBuff, batBuff, volBuff);
// Try a total of three times if the post was unsuccessful (try additional 2 times)
while (counter < 3 && !fona.postData("www.dweet.io", 443, "HTTPS", URL)) { // Server, port, connection type, URL
Serial.println(F("Failed to complete HTTP/HTTPS request..."));
counter++; // Increment counter
#else
sprintf(URL, "http://dweet.io/dweet/for/%s?temp=%s&bat=%s&vol=%s", imei, tempBuff, batBuff, volBuff);
while (counter < 3 && !fona.postData("GET", URL)) {
Serial.println(F("Failed to post data, retrying..."));
#endif
#elif defined(PROTOCOL_HTTP_POST)
// You can also do a POST request instead
sprintf(body, "{\"lat\":%s,\"long\":%s}\r\n", latBuff, longBuff); // Terminate with CR+NL
sprintf(URL, "POST /dweet/for/%s HTTP/1.1\r\nHost: dweet.io\r\nContent-Length: %i\r\n\r\n", imei, strlen(body));
while (counter < 3 && !fona.postData("www.dweet.io", 443, "HTTPS", URL, body)) { // Server, port, connection type, URL
#else
sprintf(URL, "http://dweet.io/dweet/for/%s", imei);
sprintf(body, "{\"lat\":%s,\"long\":%s}", latBuff, longBuff);
// Let's try a POST request to thingsboard.io
// Please note this can me memory-intensive for the Arduino Uno
// and may not work. You might have to split it up into a couple requests
// and send part of the data in one request, and the rest in the other, etc.
// Perhaps an easier solution is to swap out the Uno with an Arduino Mega.
const char * token = "qFeFpQIC9C69GDFLWdAv"; // From thingsboard.io device
sprintf(URL, "http://demo.thingsboard.io/api/v1/%s/telemetry", token);
sprintf(body, "{\"lat\":%s,\"long\":%s,\"speed\":%s,\"head\":%s,\"alt\":%s,\"temp\":%s,\"batt\":%s}", latBuff, longBuff,
speedBuff, headBuff, altBuff, tempBuff, battBuff);
// sprintf(body, "{\"lat\":%s,\"long\":%s}", latBuff, longBuff); // If all you want is lat/long
while (counter < 3 && !fona.postData("POST", URL, body)) {
Serial.println(F("Failed to complete HTTP POST..."));
counter++;
#endif
#endif
//Only run the code below if you want to turn off the shield after posting data
#ifdef turnOffShield
// Disable GPRS
// Note that you might not want to check if this was successful, but just run it
// since the next command is to turn off the module anyway
// Turn off GPS
if (!fona.enableGPS(false)) Serial.println(F("Failed to turn off GPS!"));
// Power off the module. Note that you could instead put it in minimum functionality mode
// instead of completely turning it off. Experiment different ways depending on your application!
// You should see the "PWR" LED turn off after this command
// if (!fona.powerDown()) Serial.println(F("Failed to power down FONA!")); // No retries
counter = 0;
while (counter < 3 && !fona.powerDown()) { // Try shutting down
#endif
// Alternative to the AT command method above:
// If your FONA has a PWRKEY pin connected to your MCU, you can pulse PWRKEY
// LOW for a little bit, then pull it back HIGH, like this:
// digitalWrite(PWRKEY, LOW);
// delay(600); // Minimum of 64ms to turn on and 500ms to turn off for FONA 3G. Check spec sheet for other types
// delay(1300); // Minimum of 1.2s for SIM7000
// digitalWrite(PWRKEY, HIGH);
// Shut down the MCU to save power
#ifndef samplingRate
Serial.println(F("Shutting down..."));
delay(5); // This is just to read the response of the last AT command before shutting down
MCU_powerDown(); // You could also write your own function to make it sleep for a certain duration instead
#else
// // The following lines are for if you want to periodically post data (like GPS tracker)
// Serial.print(F("Waiting for ")); Serial.print(samplingRate); Serial.println(F(" seconds\r\n"));
// delay(samplingRate * 1000UL); // Delay
// Only run the initialization again if the module was powered off
// since it resets back to 115200 baud instead of 4800.
fona.powerOn(FONA_PWRKEY); // Powers on the module if it was off previously
moduleSetup();
#endif
#endif
