Cuttable project boxes?
Salivations!
Ive been using project boxes from Jameco, and I'd like to be able to cut into them to mount toggles and buttons. But I find the plastic difficult to cut, and impossible to do so with any precision. I'm wondering if anyone can recommend a project box that is easy to cut yet strong enough to provide support for the toggles and buttons?
Thanks!
Can you point to the boxes you have been using so far ?
Maybe you should make boxes out of plexiglass, which is easy to work with..
I use Really Useful Boxes. Easy to drill clean holes with a Unibit (step drill), work holes with a box cutter.
Removable, see thru lids with latches. Put a screw thru a hole in the handles if you don't want them removed.
Different colors if you want.
Not brittle & easy cracking like many clear plastic cases.
Easy to obtain.
Couple examples:
CrossRoads, those look great.
Thanks all for the replies!
