I am looking for a simple way of removing voltages under a certain level.
I have been successful in doing this with a the use of an LED, but the drop in voltage is far too much.
This is for a synthesizer I have been working on. The voltage controlled amplitude module works well, except that when it should be silent, you can still just barely hear the sounds of the input signal.
Verbal description probably won't be very effective for this question.
I agree, except has there been a 'verbal' description so far posted.
Without an operational definition of "removing voltages " there is too much room for us not understanding your requirements. Does remove mean voltage should measure zero below the defined threshold? Does it mean the measurement point should be 'floating' below the threshold? Along with a circuit drawing a clear discription of what it is that you are trying to accomplish would be most useful.
i know there are noise gate circuits out there, but the ones i see are usually variable (i just need something constant) and i'm trying to keep this schematic as simple as possible.
the diode will reduce all voltages though, you should be aware of that.
you could use a 1381 voltage controlled trigger integrated circuit, but I think the lowest trigger voltage they go to is 2v, so it may not be suitable, and they are getting harder to find.
another option is the Maxim 8212, which should be more configurable, and is easy to find, but is only available as a smt device.
both of the above are meant as voltage supervisors, so I don't know how good their audio performance will be.
