Has anyone try to cut a slot in a commercially made PCB by placing Vias close together?
Example:
Can't you use "mousebites" (a row of holes) instead of copper-lined vias?
Leo..
I believe OSH Park does slots.
Or, are you trying to cut the slot after the fact?
All the cheap Chinese do slots, and at least Seeed also does good v-cut, if this is about breaking apart.
New design, using an old PCB program that does not handle slots.
I have a component with rectangular terminals, ~.35” X .05”
Would like the slot to be PTH.
Thought slots might be made as shown, don’t care if they are jagged.
I have emailed the PCB house but no response yet.
I recall that "slot" is nothing more than geometry on a certain layer. You may be able to directly edit the Gerber file(s) moving vias / solder pads / whatever geometry you used to the necessary layer.
