I am trying to use an industrial soil temperature, humidity and conductivity sensor together with a LoRa heltec. one LoRa works as a transmitter and will transmit the sensor data to another LoRa that will work as a receiver and will receive the data and send it to thingspeak. For some reason I'm only getting random data and the receiver is sending blank data to thingspeak. Below are the codes:
Sender
#include <stdlib.h>
#include <HardwareSerial.h>
#include "heltec.h"
#define BAND 915E6
#define RE 14
#define DE 13
const byte inq[] = {0x01, 0x03, 0x00, 0x00, 0x00, 0x03, 0x05, 0xCB};
byte values[13];
HardwareSerial mod(2); // RX=16 , TX =17
String rssi = "RSSI --";
String packsize = "--";
String packet ;
mod.begin(4800, SERIAL_8N1, 16, 17);
pinMode(RE,OUTPUT);
pinMode(DE,OUTPUT);
Heltec.begin(true,true,true,true,true);
Heltec.display->init();
Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
delay(1500);
Heltec.display->clear();
Heltec.display->drawString(0,0,"Heltec.Lora OK!");
Heltec.display->display();
double val1, val2, val3;
Hum();
val1 = double((values[3]*256) + values[4]) / 1000;
val2 = double((values[5]*256) + values[6]) / 10;
val3 = double((values[7]*256) + values[8]) / 1000;
char val1string[5];
dtostrf(val1,3,1,val1string);
char val2String[5];
dtostrf(val2,3,1,val2String);
char val3String[5];
dtostrf(val3,3,1,val3String);
String strUmidade (val1string);
String strTemperatura (val2String);
String strCondutividade (val3String);
Serial.print("Sinal de umidade: ");
Serial.println(val1, 6);
Serial.print("Temperatura: ");
Serial.print(val2, 2);
Serial.println(" ºC");
Serial.print("Condutividade: ");
Serial.print(val3, 6);
Serial.println(" ds/m");
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
Heltec.display->drawString(0,0,"Enviando Dados:");
Heltec.display->drawString(0,20,"Temp: ");
Heltec.display->drawString(35,20,strTemperatura+" °C");
Heltec.display->drawString(0,35,"Umid: ");
Heltec.display->drawString(35,35,strUmidade+" %");
Heltec.display->drawString(0,50,"Cond: ");
Heltec.display->drawString(35,50,strCondutividade+" ds/m");
LoRa.beginPacket();
LoRa.setTxPower(14,RF_PACONFIG_PASELECT_PABOOST);
LoRa.print(val1);
LoRa.print(val2);
LoRa.print(val3);
LoRa.endPacket();
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
void Hum(){
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
delay(10);
if (mod.write(inq, sizeof(inq)) == 8) {
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
for(byte i = 0; i < 13; i++) {
values[i] = mod.read();
Serial.print(values[i], HEX);
Serial.print(" ");
Receiver
#include "heltec.h"
#include <WiFi.h>
const char* ssid = "Fofinho"; // Change this to your WiFi SSID
const char* password = "Aaik1987"; // Change this to your WiFi password
String apiKey ="VS9PCKIKLMJP95S7";
const char* server = "api.thingspeak.com";
#define BAND 915E6
String packet ;
String umidade;
String temperatura;
String condutividade;
WiFiClient client;
WiFi.begin(ssid, password); //Start wifi connection
Serial.print("Conectando...");
while (WiFi.status() != WL_CONNECTED) { //Check for the connection
Serial.print(".");
Serial.print("Conectado com o IP: ");
delay(1500);
Heltec.display->drawString(0,0, "Lora OK! Conectado WIFI");
Heltec.display->drawString(0,10,"Esperando dados...");
//LoRa.onReceive(cbk);
LoRa.receive();
int packetSize = LoRa.parsePacket();
if(packetSize) { cbk(packetSize); }
if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr +="&field1=";
postStr += String(temperatura);
postStr +="&field2=";
postStr += String(umidade);
postStr +="&field3=";
postStr += String(condutividade);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.println("% send to Thingspeak");
Serial.println("Waiting…");
// thingspeak needs minimum 15 sec delay between updates
delay(15000);
void LoRaData(){
Heltec.display->drawString(0,0,"Dados Recebidos:");
Heltec.display->drawStringMaxWidth(0,20,128,"Temp: " + temperatura + " °C");
Heltec.display->drawStringMaxWidth(0,35,128,"Umid: " + umidade + " %");
Heltec.display->drawStringMaxWidth(0,50,128,"Cond: " + condutividade + " ds/m");
void cbk(int packetsize) {
packet ="";
packsize = String(packetsize, DEC);
for (int i = 0; i < packetsize; i++) {
char c = (char)LoRa.read();
packet += c;
//rssi = "RSSI" + String(LoRa.packetRssi(), DEC);
// Separar os valores de umidade e temperatura
temperatura = packet.substring(0, 4);
umidade = packet.substring(5, 9);
condutividade = packet.substring(10, 14);
LoRaData();
