Cycle between High and LOW signal every milliseconds for 6 seconds
Nice thanks for the feedback. I got my code to work by setting a Boolean variable in a timer loop which is pretty effective. However, this only works the first time the start button is pressed. When the start button is pressed a second time nothing happens. If i reset the board twice it works again for the first button press. Is there any way to adjust the code so the last two if loops are activated every time the start button is pressed?
const int solenoid = 10; //Output to solenoid relay
const int Step = 9; //output Stepper motor driver pulse signal
const int step_dir = 8; //output Low=CW High=CCW direction output to step driver
const int button = 7; //input for start button
const int cylswitch = 6; //input cylinder switch
const int stepdirection = 5; //input for direction of stepper motor
int cylstate; //state of solenoid and cylinders it actuates
int buttonstate; //7 state of button high/low input from start button
int dirstate;  //5 state of stepper direction high/low input from directional switch
int stepstate; //state of stepper motor pulse
int solstate; //6 state of solenoid high/low
unsigned long overallstarttime;
unsigned long previousmicros; //time tracking variable
unsigned long Timeinterval = 6000000; //overall time interval to run step motor
unsigned long stepinterval = 1; //time per step om motor
unsigned long currenttime;
boolean stepping = true; //statement to control overall time of step motor running
  pinMode(button, INPUT_PULLUP);
  pinMode(stepdirection, INPUT_PULLUP);
  pinMode(cylswitch, INPUT_PULLUP);
  pinMode(solenoid, OUTPUT);
  pinMode(step_dir, OUTPUT);
  pinMode(Step, OUTPUT);
  digitalWrite(step_dir, LOW);
  digitalWrite(Step, LOW);
  overallstarttime = micros();
  previousmicros = overallstarttime;
  //Read states of inputs
  dirstate = digitalRead(stepdirection);
  buttonstate = digitalRead(button);
  cylstate = digitalRead(cylswitch);
  //start button is pressed strobe is clamped activating cylswitch input to LOW
  if (buttonstate == HIGH) {
    solstate = HIGH;
  }//start button is not pressed strobe is released
  else {
    solstate = LOW;
  //when air cylinder switch and start buttons are active turn on stepper motor with 1 microsencond step time
  if ((buttonstate == HIGH) && (cylstate == LOW)) {
    currenttime = micros();
    if (currenttime - previousmicros > stepinterval && stepping) {
      digitalWrite(Step, !digitalRead(Step));
      previousmicros = previousmicros + stepinterval;
    //track 6s time interval for stepper motor to run
    if (currenttime - overallstarttime >= Timeinterval && stepping) {
      stepping = false;
  //write output states
  digitalWrite(Step, stepstate);
  digitalWrite(solenoid, solstate);
  digitalWrite(step_dir, dirstate);
