Hi, I am working on my first coding project and adapted the code from Adafruit Examples and want to add a new RAINBOW effect. Che code should eliminate all the delays to make the button responsive all the time. But my effect runs way to fast (LEDs are practically just blinking instead of changing colors slowly). Yes, it is responsive on button press as it should. If I add a delay of 500 at the end of "void RainbowUpdate()" if works just fine but I cant move on to another effect with the button anymore until the full cycle is completed.
I added my new rainbow effect in the exact same way as the RAINBOW_CYCLE is done and this effect runs slowly and is responsive to a button press. I don't quite understand why my new effect isn't working.
How do I need to change the code to run the RAINBOW effect in slow speed and be able to move on to the next effect with a press of the button?
// Pattern types supported:
enum pattern { NONE, RAINBOW_CYCLE, RAINBOW, COLOR_WIPE };
// Patern directions supported:
enum direction { FORWARD, REVERSE };
class NeoPatterns : public Adafruit_NeoPixel
public:
//Member variables:
pattern ActivePattern; // which pattern is running
direction Direction; // direction to run the pattern
unsigned long Interval; // milliseconds between updates
unsigned long lastUpdate; // last update of position
uint32_t Color1, Color2; // What colors are in use
uint16_t TotalSteps; // total number of steps in the pattern
uint16_t Index; // current step within the pattern
void (*OnComplete)();
// Constructor - calls base-class constructor to initialize strip
NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type)
: Adafruit_NeoPixel(pixels, pin, type)
void Update()
if ((millis() - lastUpdate) > Interval) // time to update
lastUpdate = millis();
switch (ActivePattern)
case COLOR_WIPE:
ColorWipeUpdate();
case RAINBOW_CYCLE:
RainbowCycleUpdate();
case RAINBOW:
RainbowUpdate();
default:
// Increment the Index and reset at the end
void Increment()
if (Direction == FORWARD)
Index++;
if (Index >= TotalSteps)
Index = 0;
if (OnComplete != NULL)
OnComplete(); // call the comlpetion callback
else // Direction == REVERSE
--Index;
if (Index <= 0)
Index = TotalSteps - 1;
void Rainbow(uint8_t interval, direction dir = FORWARD)
ActivePattern = RAINBOW;
Interval = interval;
TotalSteps = 255;
Index = 0;
Direction = dir;
void RainbowUpdate() {
uint16_t i, j;
for (j = 0; j < 256; j++) {
for (i = 0; i < numPixels(); i++)
setPixelColor(i, Wheel((i + j) & 255));
show();
Increment();
void RainbowCycle(uint8_t interval, direction dir = FORWARD)
ActivePattern = RAINBOW_CYCLE;
TotalSteps = 255;
Index = 0;
Direction = dir;
void RainbowCycleUpdate()
for (int i = 0; i < numPixels(); i++)
setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
show();
Increment();
void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
ActivePattern = COLOR_WIPE;
TotalSteps = numPixels();
Color1 = color;
Index = 0;
Direction = dir;
// Update the Color Wipe Pattern
void ColorWipeUpdate()
setPixelColor(Index, Color1);
show();
Increment();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos)
WheelPos = 255 - WheelPos;
if (WheelPos < 85)
return Color(255 - WheelPos * 3, 0, WheelPos * 3);
else if (WheelPos < 170)
WheelPos -= 85;
return Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
#define BUTTON_PIN 2
#define PIXEL_PIN 5
#define PIXEL_COUNT 6
NeoPatterns Strip(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;
int showType = 0;
pinMode(BUTTON_PIN, INPUT_PULLUP);
Strip.begin();
Strip.ActivePattern = RAINBOW_CYCLE; //set start LED mode/color
Strip.Index = 0;
Strip.Interval = 100;
Strip.TotalSteps = 255;
Strip.setBrightness(50);
Strip.show();
Strip.Update();
bool newState = digitalRead(BUTTON_PIN);
if (newState == LOW && oldState == HIGH) {
delay(20);
if (newState == LOW) {
showType++;
if (showType > 8)
showType = 1;
startShow(showType);
oldState = newState;
Strip.Update();
void startShow(int i) {
switch (i) {
case 0: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(0, 0, 0); //off
Strip.Interval = 30;
Strip.Update();
Serial.println(showType);
Serial.println(Strip.ActivePattern);
case 1: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(255, 0, 255); //pink
Strip.Update();
case 2: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(200, 255, 0); //Green
Strip.Update();
case 3: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(0, 250, 255); //türkis
Strip.Interval = 20;
Strip.Update();
case 4: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(255, 150, 0); //orange
Strip.Update();
case 5: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(125, 0, 255); //lila
Strip.Update();
case 6: Strip.ActivePattern = COLOR_WIPE;
Strip.Index = 0;
Strip.Color1 = Strip.Color(255, 255, 255); //weiss
Strip.Update();
case 7: Strip.ActivePattern = RAINBOW_CYCLE;
Strip.Index = 0;
Strip.Update();
case 8: Strip.ActivePattern = RAINBOW;
Strip.Index = 0;
Strip.Update();
test_led1.ino (6.45 KB)
