Cycling LCD display without using delay() in code? - SOLVED
I've tried to adapt the blinkwithout delay example for displaying two sets of information on a LCD screen.
The code is posted below, but does not work as expected.
It keeps cycling through the displays so quickly that only a faint haze of one of the items to be printed can be seen on the screen. if I uncomment the //delay (2000); the LCD display changes every 2 seconds, displaying both sets of info normally.
Is there any way to cycle the display without using delays?
#include <LiquidCrystal.h>
//create object to control an LCD.
LiquidCrystal lcd(9, 8, 7, 10, 14, 2);  // this was 12,11,5,3,2 but 5 is taken,
long previousLCDMillis = 0;    // for LCD screen update
long lcdInterval = 4000;
  // start serial port
  Serial.println("Sensor is Starting Up");
  //Welcome Message
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0, 0);          // set the cursor to column 0, line 0
  lcd.print("Sensor");
  lcd.setCursor(0, 1);          // set the cursor to column 0, line 1
  lcd.print("initialising...");
  // delay(2000);   // to show message on screen}
  // (note: line 1 is the second row, since counting begins with 0):
  // Print a message to the LCD.
   unsigned long currentLCDMillis = millis();
   if(currentLCDMillis - previousLCDMillis > lcdInterval) {             // save the last time you changed the display
      previousLCDMillis = currentLCDMillis;
  lcd.clear();
  lcd.print("Temperature");
  lcd.print("temperature");      //send the data to the computer
  lcd.print((char)223);         // degree symbol
  lcd.print("C");
  else {
  lcd.clear();
  lcd.print("Humidity");
  lcd.print("humidity");
  lcd.print("%");
  1. use functions, they give overview in the main loop()
  2. after the interval you want to change the content of the display, define an id for the 'screen' to show ==> int screen ; + some extras
modded your code => something like this? (not tested if it compiles)
// screen to show
int screen = 0;
int screenMax = 2;
bool screenChanged = true;   // initially we have a new screen,  by definition
// defines of the screens to show
#define TEMPERATURE 0
#define HUMIDITY       1
#define TIME              2
// display functions
void showWelcome()
  lcd.clear();
void showTemperature(int T)
  lcd.clear();
  lcd.print(T);
  lcd.print("C");
void showHumidity(int H)
  lcd.clear();
  lcd.print(H);
  lcd.print("%");
void showTime()
  lcd.clear();
  lcd.print("Time in seconds");
  lcd.print(millis() / 1000);
  lcd.begin(16, 2);
  showWelcome();
  // MUST WE SWITCH SCREEN?
  if(currentLCDMillis - previousLCDMillis > lcdInterval)              // save the last time you changed the display
    screen++;
    if (screen > screenMax) screen = 0;  // all screens done? => start over
  // debug Serial.println(screen);
  // DISPLAY CURRENT SCREEN
  if (screenChanged)   -- only update the screen if the screen is changed.
    screenChanged = false; // reset for next iteration
    switch(screen)
    case TEMPERATURE:
      showTemperature(40);
    case HUMIDITY:
      showHumidity(50);
    case TIME:
      showTime();
    default:
      // cannot happen -> showError() ?
As you can see the int screen holds which screen has to be shown. In the code the variable screenChanged takes care that the LCD is not written to if not necessary. This free processor time to do something usefull
Hopes this helpes
Dear robtillaart,
Thank you very much for your kind reply. It works perfectly and does exactly what I was looking for!
Thank you!
