Hi , everyone! I am currently making a cycling power meter that measures the force applied at the cleat of the cycling shoe and the RPM is calculated using a hall sensor. This is my first ever arduino project and Ive ran into some difficulties with the code. I have code that calculates the cadence by counting the amount of time it takes to make five revolutions, before displaying the power. However the method I am using means the cadence will never be zero. I know Ive made my code so that it wont display anything unless w>0 however I need that to be. This is because I have to do a detach interrupt while the data is being displayed so that things wont go crazy during operation. If that loop was continuously going the attach interrupt would never be activated. Thats why in the code the display doesnt go unless w>0. Hope that makes sense.
However this means if you stop peddling the power meter will always show that last cadence reading. I am struggling to find a way to change this because of my poor C++ knowledge and if someone could help me that would be great!
Notes
Power = Torque * angular velocity
Force is found using a flexiforce sensor.
Angular velocity found using a hall effect sensor.
Any question please dont hesitate to ask!
[volatile int revolutions;
float w;
unsigned long timeold;
float force;
int in=A0; //flexiforce sensor
float power;
pinMode(in,INPUT); //flexiforce sensor is an input
attachInterrupt(0, rpm_counter, RISING); //system should never miss a revolution using this function
revolutions = 0;
w = 0;
timeold = 0;
if(w != 0) { //if w>0 display values
detachInterrupt(0); //we dont want any interrupts here
force = analogRead(in)0.2; //random calibraton (ignore)
power = forcew;
Serial.print((int)force);
Serial.print("|"); //split so is compatible with MIT app inventor and SD data logger
Serial.print(w);
Serial.print("|");
Serial.println(power);
w=0;
attachInterrupt(0, rpm_counter, RISING); //re-attach interupt
if (revolutions >= 5) { //after five revolutions
w = revolutions*((2*3.141)*1000)/((millis() - timeold)); //calculates angular velcoity
timeold = millis(); //ready for next calculation
revolutions = 0; //set revolutions back to 0.
void rpm_counter()
revolutions = revolutions+1; //adds one revolution when hall sensor is activated
