cycling through an array
I am new to coding and I am trying to understand how to cycle through an array, one element at a time. I thought that I needed a for loop at first, but this simply cycles through the entire array. How can I manually step through an array?
Background: My sketch drives a touchscreen TFT controlled Si4703 FM Stereo Module. I have no trouble tuning using the touchscreen. Instead of tuning using the seek functions, I wanted to tune through a list of preset stations - hence the array:
int myStations[5] = {911, 985, 1011, 1051}; //array storing multiple stations
If I set it up like this,
for (int i = 0; i<5; i=i+1){ //trying to set up an array for scrolling through
channel = myStations*; //favorite stations*
  • tft.fillRoundRect(160, 40, 140, 25,6, HX8357_BLACK); //erase part of the screen for new station*
  • radio.setChannel(channel); //set new station*
  • delay(2000);*
    the tuning scrolls through the array and stops at 0MHz (the null value of the array).
    When I tried without a for loop like this,
  • int i*
  • int n = i+1;*
  • channel = myStations[n]; //favorite stations*
  • tft.fillRoundRect(160, 40, 140, 25,6, HX8357_BLACK);*
  • radio.setChannel(channel);*
  • delay(2000);*
  • i = n+1;*
    the tuning advances to the next station in the array and is stuck there.
    How do I set up an incrementing counter n to keep advancing to the next value in the array and then wrap around when it reaches the last value in the array?
It looks like you are declaring i each time through loop() although it is impossible to be sure as you have not posted a complete program (HINT !)
Why mess around with 2 variables ? Just add 1 to the array index variable to move through the array
Thanks for the quick response. I am attaching the code for your reference. The functionality I am working on is in the controlRadio() function. The initial station (referred to as “channel” from the original code I was copying) is set on line 133. I am not clear on how to use a variable as a counter to increment through the array. A counter variable makes more sense to me seeing it in a for loop.
Si4703_Radio_TFT_Amp_RTC_test1.ino (14.9 KB)
  controlRadio();                                                   //call controlRadio function
If you cut out all the dumb comments, you could've posted you code.
rzelko:
int stationIndex = 0;
void setup
void loop
  if (cycleCondition == true)
    stationIndex++;
const uint16_t myStations [] = {911, 985, 1011, 1051};
byte stationIndex;
void setup
void loop
    stationIndex++;
    // some bounds-checking code here based on "sizeof (myStations) / sizeof (myStations [0])"
Thanks for the all the input. I see how it’s done now. I have it cycling through the array, but I’m a bit confused as to how to add the bounds-checking code that was suggested. I understand the theory of “sizeof” but I have never attempted it.
Would it be done as an embedded if statement or as an else to the my if statement?
if(stationIndex<5){
channel = myStations[stationIndex];
stationIndex++;
} else stationIndex=0;
Doing it per the above code, I am successful resetting the index to recycle, however it still sends me to a null station. Perhaps the “sizeof” approach would yield different results??
rzelko:
  if (stationIndex < 5) // for an array of 5 stations array size is 6 (for the null)
    stationIndex++;
    stationIndex = 0;
you need to change your check to <4 if you have 4 stations because your array is 0 indexed, so station 1 is index 0, station 4 is index 3, null is 4.
Got it. Thank you so much for the input. You’ve been most helpful.
Before I steer off in another direction that may prove to be a dead end, is there a way to write to an array from within a user interface? I am building a menu driven version to additionally control an MP3 player and incorporate a RTC module. I would like to be able to add stations to the array from user input. Is that possible?
rzelko:
int myArray[6];
int myArrayIndex;
/*... more code
myArrayIndex = whereIWantToStoreInterfaceInput;
myArray[myArrayIndex] = InterfaceInput;
/*... more code
rzelko:
You will have to limit the number of stations that can be input to the size of your array -1 (for the null). You can populate the array with default values (0) and perform a check on the station value (!= 0) before changing the channel to the station. maybe if the value is 0 it indexes and performs the check again, cycling through the unused (default 0) stations.
