D13 triggers when powering up (simon says)
Hi there fellow Arduino-Enthusiasts. I am having a little trouble with the following code. I am new to Arduino programming and i am having the issue that output 13 gets triggered for a moment when i connect the arduino to a battery (its a geocache). since pin 13 triggeres a lock thats kinda bad. maybe someone can help me with pin 13 firing when connected to a power supply.
20150307 ekristoff Adapted from SparkFun Inventor's Kit Example sketch 16
SIK Experiment Guide for Arduino - V3.2 - SparkFun Learn
Simon tones from Wikipedia
  • A (red) - 440Hz
  • a (green) - 880Hz
  • D (blue) - 587.33Hz
  • G (yellow) - 784Hz
  • Public Constants
// NOTE FREQUENCIES
#define C3 130.81
#define Db3 138.59
#define D3 146.83
#define Eb3 155.56
#define E3 164.81
#define F3 174.61
#define Gb3 185.00
#define G3 196.00
#define Ab3 207.65
#define LA3 220.00
#define Bb3 233.08
#define B3 246.94
#define C4 261.63
#define Db4 277.18
#define D4 293.66
#define Eb4 311.13
#define E4 329.63
#define F4 349.23
#define Gb4 369.99
#define G4 392.00
#define Ab4 415.30
#define LA4 440.00
#define Bb4 466.16
#define B4 493.88
#define C5 523.25
#define Db5 554.37
#define D5 587.33
#define Eb5 622.25
#define E5 659.26
#define F5 698.46
#define Gb5 739.99
#define G5 783.99
#define Ab5 830.61
#define LA5 880.00
#define Bb5 932.33
#define B5 987.77
// DURATION OF THE NOTES
#define BPM 240 //you can change this value changing all the others
#define Q 60000/BPM //quarter 1/4
#define H 2Q //half 2/4
#define T 3
Q //three quarter 3/4
#define E Q/2 //eighth 1/8
#define S Q/4 // sixteenth 1/16
#define W 4*Q // whole 4/4
// CHECKS FOR BUTTON AND LIGHT POSITIONS
#define CHOICE_OFF 0 //Used to control LEDs
#define CHOICE_NONE 0 //Used to check buttons
#define CHOICE_RED (1 << 0)
#define CHOICE_GREEN (1 << 1)
#define CHOICE_BLUE (1 << 2)
#define CHOICE_YELLOW (1 << 3)
// DEFINE PIN LOCATIONS
#define LED_RED 8
#define LED_GREEN 10
#define LED_BLUE 12
#define LED_YELLOW 6
#define BUTTON_RED 7
#define BUTTON_GREEN 9
#define BUTTON_BLUE 11
#define BUTTON_YELLOW 5
#define BUZZER 4
#define LOCK 13
// GAME PARAMETERS
#define ENTRY_TIME_LIMIT 3000 //Amount of time to press a button before game times out. 3000 ms = 3 sec
int ROUNDS_TO_WIN = 1; //Number of rounds to succeasfully remember before you win.
// GAME STATE
byte gameBoard[32]; //Contains the combination of buttons as we advance
byte gameRound = 0; //Counts the number of succesful rounds the player has made it through
void setup() // Run once when power is connected
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
pinMode(BUTTON_RED, INPUT_PULLUP);
pinMode(BUTTON_GREEN, INPUT_PULLUP);
pinMode(BUTTON_BLUE, INPUT_PULLUP);
pinMode(BUTTON_YELLOW, INPUT_PULLUP);
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
pinMode(LED_YELLOW, OUTPUT);
attractMode(); // Blink lights while waiting for user to press a button
// Indicate the start of game play
setLEDs(CHOICE_RED | CHOICE_GREEN | CHOICE_BLUE | CHOICE_YELLOW); // Turn all LEDs on
setLEDs(CHOICE_OFF); // Turn off LEDs
delay(250);
// Play memory game and handle result
if (play_memory() == true)
play_winner(); // Player won, play winner tones
play_loser(); // Player lost, play loser tones
//THE FOLLOWING FUNCTIONS CONTROL GAME PLAY
// Play the memory game
// Returns 0 if player loses, or 1 if player wins
boolean play_memory(void)
randomSeed(millis()); // Seed the random generator with random amount of millis()
gameRound = 0; // Reset the game to the beginning
while (gameRound < ROUNDS_TO_WIN)
add_to_moves(); // Add a button to the current moves, then play them back
playMoves(); // Play back the current game board
// Then require the player to repeat the sequence.
for (byte currentMove = 0 ; currentMove < gameRound ; currentMove++)
  byte choice = wait_for_button(); // See what button the user presses
  if (choice == 0) return false; // If wait timed out, player loses
  if (choice != gameBoard[currentMove]) return false; // If the choice is incorect, player loses
delay(1000); // Player was correct, delay before playing moves
return true; // Player made it through all the rounds to win!
// Plays the current contents of the game moves
void playMoves(void)
toner(gameBoard[currentMove]);
// Wait some amount of time between button playback
// Shorten this to make game harder
delay(150); // 150 works well. 75 gets fast.
// Adds a new random button to the game sequence, by sampling the timer
void add_to_moves(void)
byte newButton = random(0, 4); //min (included), max (exluded)
// We have to convert this number, 0 to 3, to CHOICEs
if(newButton == 0) newButton = CHOICE_RED;
else if(newButton == 1) newButton = CHOICE_GREEN;
else if(newButton == 2) newButton = CHOICE_BLUE;
else if(newButton == 3) newButton = CHOICE_YELLOW;
gameBoard[gameRound++] = newButton; // Add this new button to the game array
//THE FOLLOWING FUNCTIONS CONTROL THE HARDWARE
// Lights a given LEDs
// Pass in a byte that is made up from CHOICE_RED, CHOICE_YELLOW, etc
void setLEDs(byte leds)
if ((leds & CHOICE_RED) != 0)
digitalWrite(LED_RED, HIGH);
digitalWrite(LED_RED, LOW);
if ((leds & CHOICE_GREEN) != 0)
digitalWrite(LED_GREEN, HIGH);
digitalWrite(LED_GREEN, LOW);
if ((leds & CHOICE_BLUE) != 0)
digitalWrite(LED_BLUE, HIGH);
digitalWrite(LED_BLUE, LOW);
if ((leds & CHOICE_YELLOW) != 0)
digitalWrite(LED_YELLOW, HIGH);
digitalWrite(LED_YELLOW, LOW);
// Wait for a button to be pressed.
// Returns one of LED colors (LED_RED, etc.) if successful, 0 if timed out
byte wait_for_button(void)
long startTime = millis(); // Remember the time we started the this loop
while ( (millis() - startTime) < ENTRY_TIME_LIMIT) // Loop until too much time has passed
byte button = checkButton();
if (button != CHOICE_NONE)
  toner(button); // Play the button the user just pressed
  while(checkButton() != CHOICE_NONE) ;  // Now let's wait for user to release button
  delay(10); // This helps with debouncing and accidental double taps
  return button;
return CHOICE_NONE; // If we get here, we've timed out!
// Returns a '1' bit in the position corresponding to CHOICE_RED, CHOICE_GREEN, etc.
byte checkButton(void)
if (digitalRead(BUTTON_RED) == 0) return(CHOICE_RED);
else if (digitalRead(BUTTON_GREEN) == 0) return(CHOICE_GREEN);
else if (digitalRead(BUTTON_BLUE) == 0) return(CHOICE_BLUE);
else if (digitalRead(BUTTON_YELLOW) == 0) return(CHOICE_YELLOW);
return(CHOICE_NONE); // If no button is pressed, return none
// Light an LED and play tone
// Red, upper left: 440Hz - A4
// Green, upper right: 880Hz - A5
// Blue, lower left: 587.33Hz - D5
// Yellow, lower right: 784Hz - G5
void toner(byte which)
setLEDs(which); //Turn on a given LED
//Play the sound associated with the given LED
switch(which)
case CHOICE_RED:
play(LA4, Q);
case CHOICE_GREEN:
play(LA5, Q);
case CHOICE_BLUE:
play(D5, Q);
case CHOICE_YELLOW:
play(G5, Q);
setLEDs(CHOICE_OFF); // Turn off all LEDs
// Play the winner sound and lights
void play_winner(void)
winner_sound();
//ACTIVATE LOCK
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
attractMode();
// We are the Champions!
void winner_sound(void)
play(F5, W);
play(E5, Q);
play(F5, Q);
play(E5, Q);
play(C5, T);
play(LA4, Q);
play(D5, H);
play(LA4, W);
// Play the loser sound/lights
void play_loser(void)
setLEDs(CHOICE_RED | CHOICE_GREEN);
play(B3,Q);
setLEDs(CHOICE_BLUE | CHOICE_YELLOW);
play(B3,Q);
play(B3,Q);
play(B3,Q);
// Show an "attract mode" display while waiting for user to press button.
void attractMode(void)
while(1)
setLEDs(CHOICE_RED);
delay(100);
if (checkButton() != CHOICE_NONE) return;
setLEDs(CHOICE_BLUE);
delay(100);
setLEDs(CHOICE_GREEN);
delay(100);
setLEDs(CHOICE_YELLOW);
delay(100);
void play(long note, int duration) {
tone(BUZZER,note,duration);
delay(1+duration);
@questmuffin, your topic has been moved to a more suitable location on the forum.
Pin 13 is used by the boot loader. If possible (not sure if you have pins free), use another pin or move the functionality of pins around.
Can you please edit your post, select all code and click the </> button; next save your post. This will apply code tags so the posted code will not be mangled and it makes it easier to read and copy.
@questmuffin Why do users choose to ignore the advice on posting code ?
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
Sap the wiring between 13 -> 12 & rewire the blue LED and buzzer.
Pin 13 will always flash at startup as this is the bootloader indicator. You can use a programmer to load the code to the chip, this will remove the bootloader, and stop this from happening.
