D:35:23: error: expected unqualified-id before '.' token
Hi I'm trying to change a program, to fit my own stepper motor driver shield, but I keep getting an error message, and I don't know how to fix it.
Error message:
d:35:23: error: expected unqualified-id before '.' token
     else TMC26XStepper.put(4 * items[itemNo].address, items[itemNo].value);
exit status 1
*strong text*
Code:
  readFromEEPROM
void readFromTMC26XStepper(uint8_t itemNo)
  if (items[itemNo].type == LIST)
    uint8_t temp;
    TMC26XStepper.get(4 * items[itemNo].address, temp);
    if (temp != 0 && temp + 1 != 0)
      if (items[temp].button[LEFT] == itemNo) items[itemNo].button[RIGHT] = temp;
    uint32_t temp;
    if (temp != 0 && temp + 1 != 0) items[itemNo].value = temp;
  writeToEEPROM
void writeToTMC26XStepper(uint8_t itemNo)
  uint8_t daughterItem = items[LINK2E].button[RIGHT];
  if (items[daughterItem].text == "on" || itemNo == LINK2E)
    if (items[itemNo].type == LIST) TMC26XStepper.put(4 * items[itemNo].address, items[itemNo].button[RIGHT]);
Please post the complete sketch so that we can see how and where the TMC26XStepper object is declared and perhaps why you are not using the EEPROM object from the EEPROM library
Which Arduino board are you using ?
I am using an arduino uno, and I am using TMC26XStepper.h and not EEPROM.h, because I am using the TOS-100 motion control, in order to control the stepper motor.
Here is the rest of the code:
#include <LiquidCrystal.h>
#include "TMC26XStepper.h"
          BASIC SETTINGS
// Stepper motor
#define NOFMICROSTEPS 32      // The number of microsteps per step
#define NOFSTEPSPER360 200    // The number of steps per revolution
#define MAXRPM 240            // Maximum RPM (rotations per minute)
#define INVERTDIRECTION true // If the carriage moves in the opposite direction, change to 'false'
// Leadscrew
#define MMPER360 2            // Leadscrew pitch, mm per revolution
// Arduino pins
#define STEP_PIN 2            // STEP pin (A4988)
#define DIRECTION_PIN 3       // DIR pin (A4988)
#define ENABLE_PIN 5        // EN pin (A4988)
#define ENDSTOP_PIN1 A1       // Endstop pin (forward movement)
#define ENDSTOP_PIN2 A2       // Endstop pin (backward movement)
#define BUZZER_PIN 4         // Buzzer pin
#define BUTTONS_PIN A0        // Button pin (lcd keypad shield)
#define DEBOUNCEDELAY 50
#define LONGPRESSDELAY 450
#define AUTOCHANGINGDELAY 300
#define NITEMS 43
#define LINK2S 12
#define LINK2E 13
#define LINK2V 20
#define LINK2T 21
#define LINK2F 22
#define LINK2DIA 41
#define LINK2LPV 42
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
struct MenuItem
  uint8_t button[4];
  uint8_t type;
  char *text;
  uint8_t address;
  uint32_t value;
enum listOfButtons {RIGHT, UP, DOWN, LEFT, SELECT, NA};
enum listOfButtonStates {RELEASE, SHORTPRESS, MEDIUMPRESS, LONGPRESS};
enum listOfPrograms {CHANGEVALUE = 200, SELECTFROMLIST, INFUSEVOLUME, INFUSETIME, REFILLVOLUME, REFILLFULL, CYCLEMODE, FIRMWAREINFO};
enum listOfItemTypes {TEXT, LIST, VOLUME, TIME, FLOWRATE, LENGTHPERVOLUME, DIAMETER};
const char firmwareInfo[] = "0.9a";
const uint16_t volumeDivider[2] = {1000, 1};
const uint16_t timeDivider[3] = {1, 60, 3600};
const uint16_t flowrateDivider[4] = {60000, 1000, 60, 1};
const float stepsPERmm = NOFSTEPSPER360 / MMPER360;
MenuItem items[NITEMS];
uint8_t lastButton = NA;
uint8_t buttonState = RELEASE;
uint32_t buttonPressTime = 0;
uint8_t currentItem = 1;
float coef;
uint8_t endStopPin;
volatile uint32_t ustepCounter;
uint32_t ustepCounterLimit;
uint32_t getValue(uint8_t itemNo);
void changeValue();
void setValue(uint8_t itemNo, uint8_t digits[8]);
void selectFromList();
void calculateActualValue(uint8_t itemNo);
void recalculateSyringe(uint8_t itemNo);
void printScreen();
void printUnits();
void printFirmwareInfo();
void printTimeAndVolume(uint16_t pumpingTime, uint32_t pumpingVolume);
void showScreensaver();
void readFromEEPROM(uint8_t itemNo);
void writeToEEPROM(uint8_t itemNo);
void getButtonState();
uint16_t valueDivider (uint8_t n);
uint8_t getElementNo(uint8_t linkToList);
void waitingForButton(uint8_t buttonCode, uint8_t itemNo);
void beep (uint16_t delayOn = 15, uint16_t delayOff = 100);
bool checkEndstop(int8_t pumpingDirection);
void infuseVolume();
void infuseTime();
void refillVolume();
void refillFull();
void pumpSingly(int8_t pumpingDirection, uint32_t flowrate, uint32_t volume);
void pumpContinuously();
uint8_t pump(uint32_t flowrate, uint32_t volume);
  setup
  lcd.begin(16, 2);
  pinMode(STEP_PIN, OUTPUT);
  pinMode(DIRECTION_PIN, OUTPUT);
  pinMode(ENABLE_PIN, OUTPUT);
  pinMode(ENDSTOP_PIN1, INPUT_PULLUP);
  pinMode(ENDSTOP_PIN2, INPUT_PULLUP);
  pinMode(BUZZER_PIN, OUTPUT);
  digitalWrite(ENABLE_PIN, HIGH);
  items[1]  = {5, 0, 2, 0, TEXT, "Infuse"};
  items[2]  = {7, 1, 3, 0, TEXT, "Refill"};
  items[3]  = {9, 2, 4, 0, TEXT, "Cycle Mode"};
  items[4]  = {10, 3, 0, 0, TEXT, "Settings"};
  items[5]  = {15, 0, 6, 1, TEXT, "Target Volume"};
  items[6]  = {16, 5, 0, 1, TEXT, "Target Time"};
  items[7]  = {17, 0, 8, 2, TEXT, "Full Refill"};
  items[8]  = {18, 7, 0, 2, TEXT, "Target Volume"};
  items[9]  = {19, 0, CHANGEVALUE, 3, FLOWRATE, "infuse flow:", 1, 120000000};
  items[10] = {20, 0, 11, 4, TEXT, "Units"};
  items[11] = {23, 10, 12, 4, TEXT, "Syringe"};
  items[12] = {25, 11, 13, 4, LIST, "Sound", 2};
  items[13] = {27, 12, 14, 4, LIST, "EEPROM", 3};
  items[14] = {FIRMWAREINFO, 13, 0, 4, TEXT, "Firmware"};
  items[15] = {29, 0, CHANGEVALUE, 5, VOLUME, "volume:", 4, 1000000};
  items[16] = {30, 0, CHANGEVALUE, 6, TIME, "time:", 5, 60000};
  items[17] = {REFILLFULL, 0, CHANGEVALUE, 7, FLOWRATE, "flowrate:", 6, 2000000};
  items[18] = {31, 0, CHANGEVALUE, 8, VOLUME, "volume:", 7, 1000000};
  items[19] = {CYCLEMODE, 0, CHANGEVALUE, 9, FLOWRATE, "refill flow:", 8, 2000000};
  items[20] = {32, 0, 21, 10, LIST, "Volume Units", 9};
  items[21] = {34, 20, 22, 10, LIST, "Time Units", 10};
  items[22] = {37, 21, 0, 10, LIST, "Flowrate Units", 11};
  items[23] = {41, 0, 24, 11, TEXT, "Diameter"};
  items[24] = {42, 23, 0, 11, TEXT, "Length/Volume"};
  items[25] = {SELECTFROMLIST, 0, 26, 12, TEXT, "on"};
  items[26] = {SELECTFROMLIST, 25, 0, 12, TEXT, "off"};
  items[27] = {SELECTFROMLIST, 0, 28, 13, TEXT, "on"};
  items[28] = {SELECTFROMLIST, 27, 0, 13, TEXT, "off"};
  items[29] = {INFUSEVOLUME, 0, CHANGEVALUE, 15, FLOWRATE, "flowrate:", 12, 2000000};
  items[30] = {INFUSETIME, 0, CHANGEVALUE, 16, FLOWRATE, "flowrate:", 13, 2000000};
  items[31] = {REFILLVOLUME, 0, CHANGEVALUE, 18, FLOWRATE, "flowrate:", 14, 2000000};
  items[32] = {SELECTFROMLIST, 0, 33, 20, TEXT, "mL"};
  items[33] = {SELECTFROMLIST, 32, 0, 20, TEXT, "uL"};
  items[34] = {SELECTFROMLIST, 0, 35, 21, TEXT, "s"};
  items[35] = {SELECTFROMLIST, 34, 36, 21, TEXT, "min"};
  items[36] = {SELECTFROMLIST, 35, 0, 21, TEXT, "h"};
  items[37] = {SELECTFROMLIST, 0, 38, 22, TEXT, "mL/s"};
  items[38] = {SELECTFROMLIST, 37, 39, 22, TEXT, "mL/min"};
  items[39] = {SELECTFROMLIST, 38, 40, 22, TEXT, "uL/s"};
  items[40] = {SELECTFROMLIST, 39, 0, 22, TEXT, "uL/min"};
  items[41] = {0, 0, CHANGEVALUE, 23, DIAMETER, "diameter:", 15, 11284};
  items[42] = {0, 0, CHANGEVALUE, 24, LENGTHPERVOLUME, "length/volume:", 16, 10000};
  for (uint8_t i = 1; i < NITEMS; i++)
    if (items[i].type != TEXT) readFromEEPROM(i);
  recalculateSyringe(LINK2DIA);
  beep();
  showScreensaver();
  loop
  uint8_t nextItem;
  getButtonState();
  if (buttonState == SHORTPRESS && lastButton != SELECT)
    buttonState = MEDIUMPRESS;
    nextItem = items[currentItem].button[lastButton];
    if (nextItem != 0 && nextItem < 200)
      currentItem = nextItem;
      printScreen();
    else if (nextItem == CHANGEVALUE) changeValue();
    else if (nextItem == SELECTFROMLIST) selectFromList();
    else if (nextItem == INFUSEVOLUME) infuseVolume();
    else if (nextItem == INFUSETIME) infuseTime();
    else if (nextItem == REFILLVOLUME) refillVolume();
    else if (nextItem == REFILLFULL) refillFull();
    else if (nextItem == CYCLEMODE) pumpContinuously();
    else if (nextItem == FIRMWAREINFO) printFirmwareInfo();
  getValue
  uint16_t divider = valueDivider(items[itemNo].type);
  uint8_t lastDigitIncrement = 0;
  if ( uint16_t(items[itemNo].value % divider) > divider / 2) lastDigitIncrement = 1;
  if (items[itemNo].value / divider > 99999999)
    items[itemNo].value = divider * 99999999;
    return 99999999;
  else return (items[itemNo].value / divider) + lastDigitIncrement;
  changeValue
void changeValue()
  uint8_t digits[8];
  uint32_t value = getValue(currentItem);
  for (int8_t i = 7; i >= 0; i--)
    digits[i] = uint8_t(value % 10);
    value /= 10;
  lcd.setCursor(0, 1);
  for (int8_t i = 0; i < 4; i++) lcd.print(digits[i]);
  lcd.cursor();
  int8_t i = 0;
  while (i >= 0 && i < 8)
    getButtonState();
    if (buttonState == SHORTPRESS || buttonState == LONGPRESS)
      if (lastButton == UP) digits[i] = (digits[i] + 1) % 10;
      else if (lastButton == DOWN) digits[i] = (digits[i] + 9) % 10;
      if (lastButton == RIGHT) i++;
      else if (lastButton == LEFT) i--;
      if (i == -1 && buttonState != SHORTPRESS) i++;
      if (i == 8 && buttonState != SHORTPRESS) i--;
      if (i < 5)lcd.setCursor(i, 1);
      else lcd.setCursor(i + 1, 1);
      if (buttonState == SHORTPRESS) buttonState = MEDIUMPRESS;
      else if (buttonState == LONGPRESS)
        uint32_t nextMillis = millis() + AUTOCHANGINGDELAY;
        while (nextMillis > millis() && buttonState == LONGPRESS) getButtonState();
  if (i == 8)
    bool isSame = true;
    for (int8_t j = 7; j >= 0 && isSame == true; j--)
      if (digits[j] != uint8_t(value % 10)) isSame = false;
      value /= 10;
    bool isZero = true;
    for (int8_t j = 7; j >= 0 && isZero == true; j--)
      if (digits[j] != 0) isZero = false;
    if (isSame == false && isZero == false)
      setValue(currentItem, digits);
      beep();
  lcd.noCursor();
  printScreen();
  setValue
  uint32_t value = 0;
  for (int8_t i = 0; i < 8; i++) value = value * 10 + digits[i];
  if (4294000000 / divider < value) items[itemNo].value = 4294000000;
  else items[itemNo].value = value * divider;
  if (itemNo == LINK2LPV || itemNo == LINK2DIA)
    recalculateSyringe(itemNo);
    writeToEEPROM(LINK2LPV);
    writeToEEPROM(LINK2DIA);
  else writeToEEPROM(itemNo);
  selectFromList
  uint8_t parentItem = items[currentItem].button[LEFT];
  items[parentItem].button[RIGHT] = currentItem;
  writeToEEPROM(parentItem);
  beep();
  currentItem = parentItem;
  printScreen();
  if (items[itemNo].type == FLOWRATE)
    float maxFlowrate = 1e9 * MAXRPM * MMPER360 / (float)items[LINK2LPV].value;
    if ((float)(items[itemNo].value) > maxFlowrate) items[itemNo].value = (uint32_t)maxFlowrate;
    float ustepsPERmin = coef * NOFMICROSTEPS * (float)items[itemNo].value;
    if (ustepsPERmin < 14.4) ustepsPERmin = 14.4;
    float multiplier;
    if (ustepsPERmin >= 229) multiplier = 15000000;
    else multiplier = 937500;
    float tempFloat = multiplier / ustepsPERmin;
    uint16_t countsPERustepActual = (uint16_t)(tempFloat + 0.5);
    tempFloat = multiplier / (float)countsPERustepActual;
    tempFloat /= (float)(coef * NOFMICROSTEPS);
    items[itemNo].value = (uint32_t)tempFloat;
  else if (items[itemNo].type == VOLUME)
    uint32_t nSteps = (uint32_t)(coef * (float)items[itemNo].value + 0.5);
    float tempFloat = (float)nSteps / coef;
  else if (items[itemNo].type == TIME)
    if (items[itemNo].value > 59994000) items[itemNo].value = 59994000;
    items[itemNo].value -= (items[itemNo].value % 1000);
  recalculateSyringe
  if (itemNo == LINK2LPV)
    float temp = 1128379 / sqrt((float)items[LINK2LPV].value);
    items[LINK2DIA].value = uint32_t(temp + 0.5);
  else if (itemNo == LINK2DIA)
    float temp = 1128379 / (float)items[LINK2DIA].value;
    temp *= temp;
    items[LINK2LPV].value = uint32_t(temp + 0.5);
  coef = ((float)items[LINK2LPV].value * stepsPERmm) * 1e-9;
  printScreen
void printScreen()
  lcd.clear();
  lcd.setCursor(0, 0);
  if (items[currentItem].type == TEXT || items[currentItem].type == LIST)
    lcd.print(F("> "));
    lcd.print(items[currentItem].text);
    if (items[currentItem].button[DOWN] != 0 && items[currentItem].button[DOWN] < 200)
      lcd.print(F("  "));
      lcd.print(items[items[currentItem].button[DOWN]].text);
    calculateActualValue(currentItem);
    char outputLine[10] = "    0.000";
    for (int8_t i = 8; i >= 0 && value > 0; i--)
      if (i != 5)
        outputLine[i] = char((value % 10) + '0');
        value /= 10;
    lcd.print(outputLine);
    printUnits();
  printUnits
void printUnits()
  lcd.print(F(" "));
  if (items[currentItem].type == VOLUME) lcd.print(items[items[LINK2V].button[RIGHT]].text);
  else if (items[currentItem].type == TIME) lcd.print(items[items[LINK2T].button[RIGHT]].text);
  else if (items[currentItem].type == FLOWRATE) lcd.print(items[items[LINK2F].button[RIGHT]].text);
  else if (items[currentItem].type == LENGTHPERVOLUME)
    lcd.print(F("mm/"));
  else if (items[currentItem].type == DIAMETER) lcd.print(F("mm"));
  printFirmwareInfo
  lcd.clear();
  lcd.print(F("version:"));
  lcd.print(F("  "));
  lcd.print(firmwareInfo);
  waitingForButton(LEFT, currentItem);
  printTimeAndVolume
  char outputLine[17] = "  0:00    0000xL";
  outputLine[14] = items[items[LINK2V].button[RIGHT]].text[0];
  uint8_t pointLocation;
  if (pumpingVolume < 100000)pointLocation = 3;
  else if (pumpingVolume < 1000000)
    pointLocation = 4;
    pumpingVolume /= 10;
    pointLocation = 6;
    pumpingVolume /= 100;
  if (pointLocation < 6)outputLine[pointLocation + 8] = '.';
  uint16_t timeDivider;
  for (int8_t i = 5; i >= 0; i--)
    if (pumpingTime > 0 && i != 3)
      if (i == 4) timeDivider = 6;
      else timeDivider = 10;
      outputLine[i] = uint8_t(pumpingTime % timeDivider) + '0';
      pumpingTime /= timeDivider;
    if (pumpingVolume > 0 && i != pointLocation)
      outputLine[i + 8] = uint8_t(pumpingVolume % 10) + '0';
  showScreensaver
  lcd.clear();
  lcd.print(F("   OpenSP 0.9   "));
  lcd.print(F("www.mass-spec.ru"));
  currentItem = 1;
  waitingForButton(NA, currentItem);
  getButtonState
  uint8_t button;
  uint8_t x = analogRead(BUTTONS_PIN) / 4;
  if (x < 13) button = RIGHT;
  else if (x < 46) button = UP;
  else if (x < 84) button = DOWN;
  else if (x < 131) button = LEFT;
  else if (x < 207) button = SELECT;
  else button = NA;
  if (button == NA)
    lastButton = NA;
  else if (button != lastButton)
    lastButton = button;
    buttonPressTime = millis();
  else if (millis() - buttonPressTime > LONGPRESSDELAY) buttonState = LONGPRESS;
  else if (millis() - buttonPressTime > DEBOUNCEDELAY && buttonState == RELEASE) buttonState = SHORTPRESS;
  valueDivider
uint16_t valueDivider (uint8_t itemType)
  if (itemType == VOLUME) return volumeDivider[getElementNo(LINK2V)];
  else if (itemType == TIME) return timeDivider[getElementNo(LINK2T)];
  else if (itemType == FLOWRATE) return flowrateDivider[getElementNo(LINK2F)];
  else if (itemType == LENGTHPERVOLUME) return 1000 / volumeDivider[getElementNo(LINK2V)];
  else if (itemType == DIAMETER) return 1;
  getElementNo
  uint8_t uppermostItem = items[linkToList].button[RIGHT];
  uint8_t elementNo = 0;
  while (items[uppermostItem].button[UP] != 0)
    uppermostItem = items[uppermostItem].button[UP];
    elementNo++;
  return elementNo;
  waitingForButton
void waitingForButton(uint8_t button, uint8_t itemNo)
  if (button == NA) while (buttonState != SHORTPRESS) getButtonState();
  else while (buttonState != SHORTPRESS || lastButton != button) getButtonState();
  currentItem = itemNo;
  printScreen();
  beep
void beep (uint16_t delayOn, uint16_t delayOff)
  uint8_t daughterItem = items[LINK2S].button[RIGHT];
  if (items[daughterItem].text == "on")
    digitalWrite(BUZZER_PIN, HIGH);
    delay(delayOn);
    digitalWrite(BUZZER_PIN, LOW);
    delay(delayOff);
  checkEndstop
  bool canMove = true;
  if (digitalRead(ENDSTOP_PIN1) == LOW && pumpingDirection > 0) canMove = false;
  else if (digitalRead(ENDSTOP_PIN2) == LOW && pumpingDirection < 0) canMove = false;
  if (canMove == false)
    lcd.clear();
    if (pumpingDirection > 0) lcd.print(F("SYRINGE IS EMPTY"));
    else if (pumpingDirection < 0) lcd.print(F("SYRINGE IS FULL"));
    beep(300);
    waitingForButton(LEFT, 1);
    return false;
  else return true;
    uint8_t temp;
    uint32_t temp;
  infuseVolume
void infuseVolume()
  int8_t pumpingDirection = 1;
  uint32_t flowrate = items[currentItem].value;
  uint32_t volume = items[items[currentItem].button[LEFT]].value;
  pumpSingly(pumpingDirection, flowrate, volume);
  infuseTime
void infuseTime()
  uint32_t pumpTime = items[items[currentItem].button[LEFT]].value;
  float tempFloat = (float)flowrate * (float)pumpTime;
  tempFloat /= 60000;
  uint32_t volume;
  if (tempFloat > 4294000000) volume = 4294000000;
  else volume = (uint32_t)tempFloat;
  refillVolume
void refillVolume()
  int8_t pumpingDirection = -1;
  refillFull
void refillFull()
  uint32_t volume = 4294000000;
  pumpSingly
  if (checkEndstop(pumpingDirection) == true)
    pump(pumpingDirection, flowrate, volume);
    beep(300);
  pumpContinuously
  int8_t pumpingDirection[2] = {1, -1};
  uint32_t flowrate[2] = {items[items[currentItem].button[LEFT]].value, items[currentItem].value};
  uint8_t i = 0;
  while (pump(pumpingDirection[i], flowrate[i], volume) != 2)
    i = 1 - i;
    beep();
  beep(300);
  pump
uint8_t pump(int8_t pumpingDirection, uint32_t flowrate, uint32_t volume)
  float tempFloat;
  ustepCounterLimit = (uint32_t)(coef * volume + 0.5);
  ustepCounterLimit *= NOFMICROSTEPS;
  float ustepsPERmin = coef * NOFMICROSTEPS * (float)flowrate;
  float multiplier;
  float ustepsPERsActual = multiplier / (float)countsPERustepActual;
  ustepsPERsActual /= 60;
  lcd.clear();
    endStopPin = ENDSTOP_PIN1;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, LOW);
    else digitalWrite(DIRECTION_PIN, HIGH);
    lcd.print(F(" >> INFUSING >> "));
    endStopPin = ENDSTOP_PIN2;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, HIGH);
    else digitalWrite(DIRECTION_PIN, LOW);
    lcd.print(F(" << REFILLING <<"));
  printTimeAndVolume(0, 0);
  TCNT1 = 0;
  TCCR1A = 0;
  TCCR1B |= (1 << WGM12);
    TCCR1B &= ~( 1 << CS12);
    TCCR1B |= (1 << CS11);
    TCCR1B |= (1 << CS10);
    TCCR1B |= (1 << CS12);
    TCCR1B &= ~( 1 << CS11);
  digitalWrite(ENABLE_PIN, LOW);
  digitalWrite(STEP_PIN, LOW);
  ustepCounter = 1;
  uint32_t ustepCounterActual;
  float coef2 = ((float)items[LINK2LPV].value * stepsPERmm * 1e-9) * (float)valueDivider(VOLUME) * NOFMICROSTEPS * 10;
  bool isManualStop = false;
  uint32_t pumpingVolume;
  uint16_t pumpingTime = 1;
  uint32_t nextMillis = millis() + 1000;
  OCR1A = (countsPERustepActual - 1);
  TIMSK1 |= (1 << OCIE1A);
  while ( (TIMSK1 & (1 << OCIE1A)) )
    getButtonState();
    if (buttonState == SHORTPRESS && lastButton == LEFT)
      lcd.print(F("  STOP PUMPING? "));
      lcd.print(F("(YES)       (NO)"));
        getButtonState();
            TIMSK1 &= ~( 1 << OCIE1A);
            isManualStop = true;
          else if (lastButton == RIGHT)
            if (pumpingDirection > 0) lcd.print(F(" >> INFUSING >> "));
            else lcd.print(F(" << REFILLING <<"));
    if (nextMillis <= millis())
      cli();
      ustepCounterActual = ustepCounter;
      sei();
      pumpingVolume = (uint32_t)(((float)ustepCounterActual / coef2) + 0.5);
      printTimeAndVolume(pumpingTime, pumpingVolume);
      pumpingTime++;
      nextMillis += 1000;
  pumpingVolume = (uint32_t)(((float)ustepCounter / coef2) + 0.5);
  if (isManualStop)
    lcd.print(F("  MANUAL STOP   "));
    return 2;
  if (ustepCounterLimit == ustepCounter - 1)
    lcd.print(F("    FINISHED    "));
    return 0;
    lcd.print(F("UNEXPECTED STOP "));
    return 1;
  ISR(TIMER1_COMPA_vect)
  digitalWrite(STEP_PIN, HIGH);
  if (ustepCounter == ustepCounterLimit) TIMSK1 &= ~( 1 << OCIE1A);
  if ( digitalRead(endStopPin) == LOW) TIMSK1 &= ~( 1 << OCIE1A);
  delayMicroseconds(10);
  ustepCounter++;
I checked the "keywords.txt" file of this TMC26XStepper.h library, and found no xxxx.get() method and no xxxx.put() method, or maybe I used the wrong library.
I downloaded the library from this link:
List of library methods.
start KEYWORD2
step KEYWORD2
setSpeed ​​KEYWORD2
getSpeed ​​KEYWORD2
setMicrosteps KEYWORD2
getMicrosteps KEYWORD2
move KEYWORD2
isMoving KEYWORD2
getStepsLeft KEYWORD2
stop KEYWORD2
setConstantOffTimeChopper KEYWORD2
setSpreadCycleChopper KEYWORD2
setRandomOffTime KEYWORD2
setCurrent KEYWORD2
getCurrent KEYWORD2
setStallGuardThreshold KEYWORD2
getStallGuardThreshold KEYWORD2
getStallGuardFilter KEYWORD2
setCoolStepConfiguration KEYWORD2
setCoolStepEnabled KEYWORD2
isCoolStepEnabled KEYWORD2
getCoolStepLowerSgThreshold KEYWORD2
getCoolStepUpperSgThreshold KEYWORD2
getCoolStepNumberOfSGReadings KEYWORD2
getCoolStepCurrentIncrementSize KEYWORD2
getCoolStepLowerCurrentLimit KEYWORD2
getMotorPosition KEYWORD2
getCurrentStallGuardReading KEYWORD2
getCurrentCSReading KEYWORD2
isCurrentScalingHalfed KEYWORD2
getCurrentCurrent KEYWORD2
isStallGuardOverThreshold KEYWORD2
getOverTemperature KEYWORD2
isShortToGroundA KEYWORD2
isShortToGroundB KEYWORD2
isOpenLoadA KEYWORD2
isOpenLoadB KEYWORD2
isStandStill KEYWORD2
isStallGuardReached KEYWORD2
setEnabled KEYWORD2
isEnabled KEYWORD2
readStatus KEYWORD2
getResistor KEYWORD2
debugLastStatus KEYWORD2
version KEYWORD2
I suggest that you look at one of the examples that come with the library that you're using. Please provide a link to the library so we don't have to wonder if we have the correct one.
Using the one provided by @ruilviana, you seem to be missing a line like
TMC26XStepper tmc26XStepper = TMC26XStepper(200,2,6,7,700);
and you must use tmc26XStepper (note the case).
This is a typical question for the Programming Questions section and hence your topic has been moved there.
