Simple d3.js Graph
PHP, SQLITE3 and Yun
http://forum.arduino.cc/index.php?topic=309101.0
Make Datafeed (data.csv) page
nano /www/sensordata.php
<?php
print "date,close\n";
$db = new SQLite3('/mnt/sda1/sensor.db');
$results = $db->query('SELECT strftime("%H:%M:%S", sqlitetimestamp), temperature from sensor_data ORDER BY id LIMIT 20;');
while ($row = $results->fetchArray()) {
print $row[0].",".$row[1]."\n";
$db->close();
Make Sensor page:
nano /www/sensor.html
<!DOCTYPE html>
<meta charset="utf-8">
<style> /* set the CSS */
body { font: 12px Arial;}
path {
stroke: steelblue;
stroke-width: 2;
fill: none;
.axis path,
.axis line {
fill: none;
stroke: grey;
stroke-width: 1;
shape-rendering: crispEdges;
</style>
<body>
<!-- load the d3.js library -->
<script src="http://d3js.org/d3.v3.min.js"></script>
<script>
// Set the dimensions of the canvas / graph
var margin = {top: 30, right: 20, bottom: 30, left: 50},
width = 600 - margin.left - margin.right,
height = 270 - margin.top - margin.bottom;
// Parse the date / time
var parseDate = d3.time.format("%H:%M:%S").parse;
// Set the ranges
var x = d3.time.scale().range([0, width]);
var y = d3.scale.linear().range([height, 0]);
// Define the axes
var xAxis = d3.svg.axis().scale(x)
.orient("bottom").ticks(5);
var yAxis = d3.svg.axis().scale(y)
.orient("left").ticks(5);
// Define the line
var valueline = d3.svg.line()
.x(function(d) { return x(d.date); })
.y(function(d) { return y(d.close); });
// Adds the svg canvas
var svg = d3.select("body")
.append("svg")
.attr("width", width + margin.left + margin.right)
.attr("height", height + margin.top + margin.bottom)
.append("g")
.attr("transform",
"translate(" + margin.left + "," + margin.top + ")");
// Get the data
d3.csv("sensordata.php", function(error, data) {
data.forEach(function(d) {
d.date = parseDate(d.date);
d.close = +d.close;
// Scale the range of the data
x.domain(d3.extent(data, function(d) { return d.date; }));
y.domain([0, d3.max(data, function(d) { return d.close; })]);
// Add the valueline path.
svg.append("path")
.attr("class", "line")
.attr("d", valueline(data));
// Add the X Axis
svg.append("g")
.attr("class", "x axis")
.attr("transform", "translate(0," + height + ")")
.call(xAxis);
svg.append("text")
.attr("transform",
"translate(" + (width/2) + " ," +
(height+margin.bottom) + ")")
.style("text-anchor", "middle")
.text("Date");
// Add the Y Axis
svg.append("g")
.attr("class", "y axis")
.call(yAxis);
svg.append("text")
.attr("transform", "rotate(-90)")
.attr("y", 6)
.attr("x", margin.top - (height / 2))
.attr("dy", ".71em")
.style("text-anchor", "end")
.text("Temperature");
</script>
</body>
Download above page:
wget https://www.dropbox.com/s/wdf2jrij3ue6k5y/sensor.html?dl=0 -O /www/sensor.html --no-check-certificate
