D3 was not declared in this scope Node MCU esp8266
Hi I want to create a code for smart irrigation using esp8266 and soil moisture sensor. I am having a hard time with the code as it is showing the error D3 was not declared in this scope
`#include <Blynk.h>
//Include the library files
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
//Initialize the LCD display
LiquidCrystal_I2C lcd(0x27, 16, 2);
char auth[] = "";//Enter your Auth token
char ssid[] = "";//Enter your WIFI name
char pass[] = "";//Enter your WIFI password
BlynkTimer timer;
bool Relay = 0;
//Define component pins
#define sensor A0
#define waterPump D3
pinMode(waterPump, OUTPUT);
digitalWrite(waterPump, HIGH);
lcd.init();
lcd.backlight();
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
lcd.setCursor(1, 0);
lcd.print("System Loading");
for (int a = 0; a <= 15; a++) {
lcd.setCursor(a, 1);
lcd.print(".");
lcd.clear();
//Call the function
timer.setInterval(100L, soilMoistureSensor);
//Get the button value
BLYNK_WRITE(V1) {
Relay = param.asInt();
if (Relay == 1) {
digitalWrite(waterPump, LOW);
lcd.setCursor(0, 1);
lcd.print("Motor is ON ");
lcd.print("Motor is OFF");
//Get the soil moisture values
void soilMoistureSensor() {
int value = analogRead(sensor);
value = map(value, 0, 1024, 0, 100);
value = (value - 100) * -1;
Blynk.virtualWrite(V0, value);
lcd.setCursor(0, 0);
lcd.print("Moisture :");
lcd.print(value);
lcd.print(" ");
Blynk.run();//Run the Blynk library
timer.run();//Run the Blynk timer
Just use the GPIO number.
#define waterPump 3
…and your post is missing one IMPORTANT thing !
Please be more specific. What board?
I think pin names like "D3" are defined for some types of esp8266 boards (like Wemos mini or NodeMCU) but not all.
As mentioned, please fix those code tags!
