D4184 Modules Load Voltage drops to near zero
Hello folks,
i am using these modules for a project:
D4184 Mosfet Modules
I drive them with a Wemos D1 mini via PWM and without a load, my 12V can be regulated fine from 0 to ~11V.
They have only 3 Pins on the circuit where the load is to be connected, Vin, Load and GND. So i connect 12V to Vin, the loads (+) to Load-Pin and both the powersource and motor (-) to GND.
As soon as i connect a load though, the voltage drops to zero and the LED on the module lights up, as it also does, when i turn the voltage to 0V via PWM. I tried that with an RC Heli Motor ( esky 180er ) and the intended load, a rumblepack. Both loads run fine when directly connected to 0 - 12V.
Update: I added a diode to prevent backflow of currency because of the motor and measured... with the motor attached, Voltage on the Load Pin is 0.63 instead of 11V when full ON.
Help my noob brain please!
d4184
You are connecting the load incorrectly. The 12 V power supply must be connected to the + and - pins, and the load to the + and Load pins.
See description and wiring diagram here
Module Connections
Thank you very much, rewired and it worked right away.
One important point to take note of is that if an inductive load is being controlled, an external fly-back diode should be used to prevent possible damage when the load is switched off.
Am i reading the diagram right - the flyback diode has to be connected parallel to the load?
Yes. Direction is from Load to "+" pin.
