D6t
Would the linked code be good for using the onion d6t as a simple switch in a circuit?
First of all how about a link to "onion d6t". I assume you are not planning to use a d6t bulldozer on your program.
Weedpharma
http://www.omron.com/ecb/products/pdf/en-d6t.pdf
Edit Sorry doesn't work for some reason. Attached file.
The link provided has some code on it, its an omron item, above is the link.
onion might be a translation problem.
Tom..... :slight_smile:
en-d6t.pdf (821 KB)
I gather from this abandoned thread, the OP wants to use detect people in a room.
I don't understand why an inexpensive PIR sensor isn't used. A PIR sensor could be used as a switch without the need of a microcontroller as wicko mentioned doing in this thread. The arduino was only added when he wanted to use two sensors (though I still the Arduino wasn't really needed).
Why a new thread? This sure seems like it's related to the previous thread. IMO, switching threads is disrespectful to the people attempting to help.
TomGeorge:
The insert a link button has put an extra "http://" into your link. You can see that if you hover over the link.
I sometimes have to edit any links in my posts multiple times to get them to work correctly.
TomGeorge:
Well, he just as likely will not pursue answers on this one either. :roll_eyes:
