DAC Arduino 2
Someone know how is the functioning on the two different dac on arduino due? In particular, if the maximum voltage level is 3.3V or it is the supply level (and so it can reach also 10 Volts)?
Thanks!
Androlo: if the maximum voltage level is 3.3V or it is the supply level (and so it can reach also 10 Volts)?
The maximum is 3.3V but a simple voltage divider will let you measure higher voltages.
