hi guys
i bought this platform kit, also known as "Dagu - Rover 5", it comes into two options, 4 motors and 4 encoders, or 2 motors and 2 encoders, both sold with tracks.
I have damaged one of my tracks, and i want to replace everything which a common pairs of rover's wheels, the problem is … i do not understand if it is possible, and in case it is, which wheels i have to buy.
if you use a 2 channel motor driver you will see a lot of interaction between the motors on the same channel/side.
Same goes for using 6 AA batteries with that battery pack they include.
Each motor has a stated stall current of 2.5A.
With 6, 2500mAh NiMh batteries I could not get mine to start below about 40% PWM, when driving around if a single wheel lost contact with the ground it would spin and "suck up" all the available drive current.
I've since gone to 2, dual channel Pololu motor drivers, these ones
If you watch the video you can see the rover has a hard time trying to climb a loose slope, the wheels spin, it looses traction.
I'm powering mine with a 7.2V LiPo pack which has plenty of current, I also put an fuse and switch on the motor power as well, just to be safe
