I have more than 1 tlc5940 connected together. i founded the NUM_TLCS in the tlc_config.h but i couldn't find tlc5940.o file. where does that located??
They are not used in the latest system as they are created on the fly at compile time so no need to worry.
cool thanks. also, can you tell me what does
uint8_t uint16_t uint32_t
mean?
mean?
The u means unsigned. The int is pretty obvious, no? The value is the number of bits in the value. The _t means that all compilers recognize the type and size and respond correctly.
define Tlc_fade_buffer_length 24
The default fade buffer length (24) Uses 24*13 = 312 bytes of ram.
Does this means that the default fade buffer length has 312 bytes of ram or does it mean that if I want to use 312 bytes of ram, I have to use 24*13? I.e. Tlc_fade_buffer_length 24*13
Also Whats the default buffer size for tl_fadeBufferSize?? I believes it's the same as Tlc_fade_buffer_length ??
Thanks
