Dalek Build, wheelchair motorization
Hey guys I'm working on making a motorized Dalek and have come across a rather embarrassing problem... I don't know how to code this project.
What I'm trying to do is use an Arduino Uno along with the USB host shield, an Xbox receiver and controller to control two wheelchair motors with the sabertooth 2x32 6-12v motorcontoller. I'm hoping to drive it tank stye with each joystick controlling one motor with throttle capabilites.
I also plan on adding another smaller motorcontroller (Sabertooth dual 12A motor driver)along with two more motors, one to control the head rotation on the Dalek and one to do the up/down motion of the eyestalk using d-pad or bumpers.
if anyone could give me a hand or some pointers I would appreciate it.
Sure we can give you a hand. It's what we do!
Break it down into small steps.
  • Does the sabertooth provider have any tutorials? Try them out to see if you can make the motors run
  • Can google up any Xbox controller examples? Have you tried them?
  • After you have successfully tested each individual component and have working code for each, combine them
Of course, if you have difficulty with any step, ask for help. Post code (using code tags like it says in the 'how to use this forum' post)
Describe what you expect the result to be and what the actual results are.
It's not important now but it might become important: what scale is the Dalek? How heavy? What terrain? That will drive a lot of decisions for motors and power supplies.
For the eyestalk, I would try to make it mostly counterbalanced and use a radio control (RC) type servo. The mechanics and feedback control are totally encapsulated and easy to buy when you get a servo.
I'm using wheelchair motors for the main movement. that's the need to get going. it's a full sized one.
I've tried the jolty example and was successful in getting that to run, however all that does is run a short program to turn a motor clockwise or counter clockwise for 2 seconds with a delay between.
Code for example here:
// Jolty Sample for Packet Serial
// Copyright (c) 2012 Dimension Engineering LLC
// See license.txt for license details. https://www.dimensionengineering.com/software/SabertoothArduinoLibrary/html/class_sabertooth.html#a1897c15b53d2eb6cd59b5b1c1254fbf1
#include <Sabertooth.h>
Sabertooth ST(128); // The Sabertooth is on address 128. We'll name its object ST.
                    // If you've set up your Sabertooth on a different address, of course change
                    // that here. For how to configure address, etc. see the DIP Switch Wizard for
                    //   Sabertooth - http://www.dimensionengineering.com/datasheets/SabertoothDIPWizard/start.htm
                    //   SyRen      - http://www.dimensionengineering.com/datasheets/SyrenDIPWizard/start.htm
                    // Be sure to select Packetized Serial Mode for use with this library.
                    // On that note, you can use this library for SyRen just as easily.
                    // The diff-drive commands (drive, turn) do not work on a SyRen, of course, but it will respond correctly
                    // if you command motor 1 to do something (ST.motor(1, ...)), just like a Sabertooth.
                    // In this sample, hardware serial TX connects to S1.
                    // See the SoftwareSerial example in 3.Advanced for how to use other pins.
  SabertoothTXPinSerial.begin(9600); // 9600 is the default baud rate for Sabertooth packet serial.
  ST.autobaud(); // Send the autobaud command to the Sabertooth controller(s).
                 // NOTE: *Not all* Sabertooth controllers need this command.
                 //       It doesn't hurt anything, but V2 controllers use an
                 //       EEPROM setting (changeable with the function setBaudRate) to set
                 //       the baud rate instead of detecting with autobaud.
                 //       If you have a 2x12, 2x25 V2, 2x60 or SyRen 50, you can remove
                 //       the autobaud line and save yourself two seconds of startup delay.
  ST.motor(1, 127);  // Go forward at full power.
  delay(2000);       // Wait 2 seconds.
  ST.motor(1, 0);    // Stop.
  ST.motor(1, -127); // Reverse at full power.
  delay(2000);
I then worked on seeing if I could get the controller to work with the ardunio which I use the example xboxrecv from the usb host shield 2.0 library. I was successful in this as the example just tells you what button you are pressing in the serial monitor.
the code for this example can be found here:
 Example sketch for the Xbox Wireless Reciver library - developed by Kristian Lauszus
 It supports up to four controllers wirelessly
 For more information see the blog post: http://blog.tkjelectronics.dk/2012/12/xbox-360-receiver-added-to-the-usb-host-library/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <XBOXRECV.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
USB Usb;
XBOXRECV Xbox(&Usb);
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nXbox Wireless Receiver Library Started"));
  Usb.Task();
  if (Xbox.XboxReceiverConnected) {
    for (uint8_t i = 0; i < 4; i++) {
      if (Xbox.Xbox360Connected[i]) {
        if (Xbox.getButtonPress(L2, i) || Xbox.getButtonPress(R2, i)) {
          Serial.print("L2: ");
          Serial.print(Xbox.getButtonPress(L2, i));
          Serial.print("\tR2: ");
          Serial.println(Xbox.getButtonPress(R2, i));
          Xbox.setRumbleOn(Xbox.getButtonPress(L2, i), Xbox.getButtonPress(R2, i), i);
        if (Xbox.getAnalogHat(LeftHatX, i) > 7500 || Xbox.getAnalogHat(LeftHatX, i) < -7500 || Xbox.getAnalogHat(LeftHatY, i) > 7500 || Xbox.getAnalogHat(LeftHatY, i) < -7500 || Xbox.getAnalogHat(RightHatX, i) > 7500 || Xbox.getAnalogHat(RightHatX, i) < -7500 || Xbox.getAnalogHat(RightHatY, i) > 7500 || Xbox.getAnalogHat(RightHatY, i) < -7500) {
          if (Xbox.getAnalogHat(LeftHatX, i) > 7500 || Xbox.getAnalogHat(LeftHatX, i) < -7500) {
            Serial.print(F("LeftHatX: "));
            Serial.print(Xbox.getAnalogHat(LeftHatX, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(LeftHatY, i) > 7500 || Xbox.getAnalogHat(LeftHatY, i) < -7500) {
            Serial.print(F("LeftHatY: "));
            Serial.print(Xbox.getAnalogHat(LeftHatY, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(RightHatX, i) > 7500 || Xbox.getAnalogHat(RightHatX, i) < -7500) {
            Serial.print(F("RightHatX: "));
            Serial.print(Xbox.getAnalogHat(RightHatX, i));
            Serial.print("\t");
          if (Xbox.getAnalogHat(RightHatY, i) > 7500 || Xbox.getAnalogHat(RightHatY, i) < -7500) {
            Serial.print(F("RightHatY: "));
            Serial.print(Xbox.getAnalogHat(RightHatY, i));
        if (Xbox.getButtonClick(UP, i)) {
          Xbox.setLedOn(LED1, i);
          Serial.println(F("Up"));
        if (Xbox.getButtonClick(DOWN, i)) {
          Xbox.setLedOn(LED4, i);
          Serial.println(F("Down"));
        if (Xbox.getButtonClick(LEFT, i)) {
          Xbox.setLedOn(LED3, i);
          Serial.println(F("Left"));
        if (Xbox.getButtonClick(RIGHT, i)) {
          Xbox.setLedOn(LED2, i);
          Serial.println(F("Right"));
        if (Xbox.getButtonClick(START, i)) {
          Xbox.setLedMode(ALTERNATING, i);
          Serial.println(F("Start"));
        if (Xbox.getButtonClick(BACK, i)) {
          Xbox.setLedBlink(ALL, i);
          Serial.println(F("Back"));
        if (Xbox.getButtonClick(L3, i))
          Serial.println(F("L3"));
        if (Xbox.getButtonClick(R3, i))
          Serial.println(F("R3"));
        if (Xbox.getButtonClick(L1, i))
          Serial.println(F("L1"));
        if (Xbox.getButtonClick(R1, i))
          Serial.println(F("R1"));
        if (Xbox.getButtonClick(XBOX, i)) {
          Xbox.setLedMode(ROTATING, i);
          Serial.print(F("Xbox (Battery: "));
          Serial.print(Xbox.getBatteryLevel(i)); // The battery level in the range 0-3
          Serial.println(F(")"));
        if (Xbox.getButtonClick(SYNC, i)) {
          Serial.println(F("Sync"));
          Xbox.disconnect(i);
        if (Xbox.getButtonClick(A, i))
          Serial.println(F("A"));
        if (Xbox.getButtonClick(B, i))
          Serial.println(F("B"));
        if (Xbox.getButtonClick(X, i))
          Serial.println(F("X"));
        if (Xbox.getButtonClick(Y, i))
          Serial.println(F("Y"));
(Is it so hard to add code tags around code listing! C'mon folks ...)
Hi Bryan,
Back in Reply #1 I suggested that your code should be posted using code tags.
This is also covered in the "How to use this forum - please read" that is at the very top of this forum, in bold text.
Since you did not use code tags, I can only assume that you have not read that post. Please do so. It makes it MUCH easier for us to help you of you follow some simple rules.
Go read the "How to use this forum - please read" post.
Go modify your post in reply #3 and use the code tags.
It looks like you have made progress on your project, successfully testing the motor and the controller.
Fix your post and we can continue helping you.
Great! It looks like you were fixing your post as I typed my latest reply!
So, your next step could be, try to combine the 2 tests into a single sketch.
Say, something that moves the motor forward when you press the A button, and moved the motor backward when you press the B button.
Give it a go. Post back here with any questions you have as you work on it.
