dallas ds1820
Hi ppl!
I´m not getting how to get the tmp value of some (in 1 of 4) dallas temperature to put in on IF STATE,
in Multiple. exemple we got the following, (changed to add more 2…)
scketch:
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer, insideThermometer2, outsideThermometer, outsideThermometer2;
void setup(void)
  Serial.println("Dallas Temperature IC Control Library Demo");
  pinMode(13, OUTPUT);
  sensors.begin();
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(insideThermometer2, 1)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(outsideThermometer, 2)) Serial.println("Unable to find address for Device 1");
  if (!sensors.getAddress(outsideThermometer2, 3)) Serial.println("Unable to find address for Device 2");
  Serial.print("Device 0 Address: ");
  printAddress(insideThermometer);
  Serial.print("Device 1 Address: ");
  printAddress(insideThermometer2);
  Serial.print("Device 2 Address: ");
  printAddress(outsideThermometer);
  Serial.print("Device 3 Address: ");
  printAddress(outsideThermometer2);
  sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
  sensors.setResolution(insideThermometer2, TEMPERATURE_PRECISION);
  sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
  sensors.setResolution(outsideThermometer2, TEMPERATURE_PRECISION);
  Serial.print("Device 0 Resolution: ");
  Serial.print(sensors.getResolution(insideThermometer), DEC);
  Serial.print(sensors.getResolution(insideThermometer2), DEC);
  Serial.print("Device 1 Resolution: ");
  Serial.print(sensors.getResolution(outsideThermometer), DEC);
  Serial.print("Device 2 Resolution: ");
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Temp F: ");
  Serial.print(DallasTemperature::toFahrenheit(tempC));
void printResolution(DeviceAddress deviceAddress)
  Serial.print("Resolution: ");
  Serial.print(sensors.getResolution(deviceAddress));
void printData(DeviceAddress deviceAddress)
  Serial.print("Device Address: ");
  printAddress(deviceAddress);
  Serial.print(" ");
  printTemperature(deviceAddress);
void loop(void)
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures();
  Serial.println("DONE");
  printData(insideThermometer);
  printData(insideThermometer2);
  printData(outsideThermometer);
  printData(outsideThermometer2);
    if(insideThermometer == 25){                              // error here
    digitalWrite(13, HIGH);
  else {
    digitalWrite(13,LOW);
(just in button)
  else {
how can the value be be catch? :?
Tks in advance any help…
The LED will be lit only if the temperature is exactly 25. Try this. The LED will be lit if the temp is at or above 25.
   if(insideThermometer >= 25){
  else {
Hi SurferTim...
Tks for reply.. but when compiled give this error..
Multiple.cpp: In function 'void setup()':
Multiple.pde:-1: error: expected primary-expression before '{' token
Multiple.pde:-1: error: expected `;' before '{' token
Multiple.cpp: In function 'void loop()':
Multiple.pde:-1: error: ISO C++ forbids comparison between pointer and integer
this is the address of DS right? Why don´t catch value?
BR
Does this
help any?
My bad. That (insideThermometer) is the device number, not the temp, correct?
TY
SurferTim and AWOL
:slight_smile: gr8
