Dallas DS18B20 Temp sensor questions
Greetings all.
I’v been playing around with these Dallas temp sensors and have followed the example codes. However, i’v managed to narrow down the code to an almost simplistic state of what i’m needing but i’m having a little hurdle i hope someone can help me with.
I’m not the best at programming yet :stuck_out_tongue: I know what i’m trying to do though. Uisng the following code:
      Dallas DS18B20 experiments
      Taking the example 'one sensor code' and minimising it to what's needed for my purposes.
      Plan is to take the sensor reading and use that info to be able to be called,  to output on
      an LCD or 7-segment display.
#include <DallasTemperature.h>    //dallas library
static const int ONE_WIRE_PIN = 12;  //data wire on pin 12
NewOneWire oneWire(ONE_WIRE_PIN);      //sets up a onewire instance
DallasTemperature tempSensor(oneWire);  //passes onewire reference to DallasTemperature
void setup(void) {
    // initialize inputs/outputs
    // start serial port
    tempSensor.begin();  //begin reading from sensor
    Serial.println("Dallas library test, minimising what's needed");
//function for siplaying the temperature on serial monitor
void display(DallasTemperature &sensor) {
    // getTemperature returns a float.
    float temperature = sensor.getTemperature();     //gets temperature reading from sensor in degrees
    Serial.print(temperature);
    Serial.print("C\t");              // adds 'C' for celcius
//main loop
void loop(void) {
    display(tempSensor);  //displays temperature in serial monitor in celcius
    Serial.println();    //
Now, this works perfectly reading the temperature in degrees on the serial monitor. What i’m trying to do, (in pseudo code) is for example:
If temp = 24C
output 24C on either an LCD or 7segment.
I have the code for these respectively, i just can’t seem to pin point the variable i need to use to do this. I’v tried loads and i think it’s something small and silly.
I tried something like:
If (temperature >= 24) {
show 24 on 7-segment
Can someone show me the way?
:slight_smile:
…so can you show the code you use to output to LCD or 7segments (so we can see why it is difficult to combine it with temperature readings)
just write lcd.print(temp); that does it for me!
This is my full code, i’m pretty sure this is a simple thing.
//7-segment set up
int a = 0;            // segment a. LSB
int b = 1;            //segment b
int c = 2;            //segment c
int d = 3;            //segment d
int e = 4;            //segment e
int f = 5;            //segment f
int g = 6;            //segment g
int dp = 7;            //decimal point. MSB
int dig1 = 8;        //common anode for 1st digit
int dig2 = 9;        //common anode for 2nd digit
void setup(void) {
    // initialize the digital pins as an output:
  pinMode(a, OUTPUT);
  pinMode(b, OUTPUT);
  pinMode(c, OUTPUT);
  pinMode(d, OUTPUT);
  pinMode(e, OUTPUT);
  pinMode(f, OUTPUT);
  pinMode(g, OUTPUT);
  pinMode(dp, OUTPUT);
  pinMode(dig1, OUTPUT);
  pinMode(dig2, OUTPUT);
//main loop
void loop(void) {
    //this is the if statement i was trying to display on 7segment, i get "temperature not declared in this scope" error.
    if (temperature >= 24) {
      number2A();
      number4B();
////////////////////////Functions for various characters 1st digit  //////////////////////////////////////
void number0A() {      //number 0
        PORTD = B11000000; //'0'
        PORTB = B00000001; // 1st digit
        delay(10);        //10ms delay
void number1A() {  //number 1
     PORTD = B11111001; //'1'
     PORTB = B00000001; //1st digit
void number2A() {  //number 2
    PORTD = B10100100;  //'2'
void number3A() {  //number 3
    PORTD = B10110000;  //'3'
    PORTB = B00000001; //1ST DIGIT
void number4A() {  //number 4
    PORTD = B10011001;  //'4'
    delay(10);  //10ms
void number5A() {  //number 5
    PORTD = B10010010;  //'5'
    delay(10);  //10ms
void number6A() {
    PORTD = B10000010;  //'6'
    delay(10);  //10ms
void number7A() {  //number 7
    PORTD = B11011000;  //'7'
    delay(10);  //delay10ms
void number8A() {   //number 8
    PORTD = B10000000;  //'8'
void number9A() {  //number 9
    PORTD = B10011000;  //'9'
    delay(10);  //10ms
void decimalp1() {  //decimal point 1
    PORTD = B01111111;  //DP1
    delay(10);  //delay 10ms
//Functions for various characters 2nd digit
void number0B() {      //number 0
        PORTB = B00000010; // 2nd digit
void number1B() {  //number 1
     PORTB = B00000010; //2nd digit
void number2B() {  //number 2
void number3B() {  //number 3
    PORTB = B00000010; //2nd DIGIT
void number4B() {  //number 4
    delay(10);  //10ms
void number5B() {  //number 5
    delay(10);  //10ms
void number6B() {
    delay(10);  //10ms
void number7B() {  //number 7
void number8B() {   //number 8
void number9B() {  //number 9
    delay(10);  //10ms
void decimalp2() {  //decimal point 1
I’m also aware that my 7-segment code isn’t particularly efficient either. :stuck_out_tongue:
void loop(void) {
    float temperature = tempSensor.getTemperature();
      number2A();
      number4B();
Do you get something using the code above? Why don't you want to display temperatures below 24? To get a brighter display you may need to refresh the 7segment display repeatedly for a while and only occasionally get a new temperature reading.
The "scope" problem was because the temperature variable was declared inside another function. You should store the bit patterns for each digit in an array and have a single function that fetches the pattern for the digits you want to display.
I don't get anything except that scope error using the above code. I did think of tying arrays. But isn't what i'm doing just a longer way of doing it? And so, would i not still get the same type of problem.
I only used the >=24 as an example to see if i was going to get anything.
I still don't quite understand how i 'fetch' the temperature info, is my above if function going along the right lines?
you 'fetch' the temperature by calling tempSensor.getTemperature(). That probably works fine already.
Your code works fine as long as you want to display "24" for temps above 24 and nothing otherwise, but it will be cumbersome if you want to display an arbitrary value on the 7segment display.
There should be no scope error if you replace the loop you had with the one I posted earlier. Please try again.
AH! My apologies, i read your last post with the code as a part of my own, i didn't realise you had changed it. Thanks very much! :D
There is now action on the display but i see i am going to have to make an array for the digits to display properly. I'm getting glitches which i think are to do with the delays of my number functions.
Thanks again.
