Dallas Temprature Compilation errors
Hello,
I am trying to compile my temprature code,but i am getting the errors below;
C:\Users\kitiku\Documents\Arduino\libraries\DallasTemp\DallasTemperature.cpp: In member function 'bool DallasTemperature::validAddress(const uint8_t*)': C:\Users\kitiku\Documents\Arduino\libraries\DallasTemp\DallasTemperature.cpp:67: error: invalid conversion from 'const uint8_t*' to 'uint8_t*'
Please assist
Kitiku
. . . which you're not going to show us?
Don't forget the code tags.
Welcome to the Forum. To help us help you, please read and follow the Forum's posting guidelines as spelled out in the two posts by Nick Gammon at the top of this Forum. They will help you get more responses to your questions.
below is my code,
I have all the libraries installed.But the errors are reported on the .cpp file.
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Exosite.h>
// Pin use
#define ONEWIRE 7 //pin to use for One Wire interface
// Set up which Arduino pin will be used for the 1-wire interface to the sensor
OneWire oneWire(ONEWIRE);
DallasTemperature sensors(&oneWire);
  • Configuration Variables
  • Change these variables to your own settings.
    String cikData = “0000000000000000000000000000000000000000”; // ← FILL IN YOUR CIK HERE! (https://portals.exosite.com → Add Device)
    byte macData = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // ← FILL IN YOUR Ethernet shield’s MAC address here.
    // User defined variables for Exosite reporting period and averaging samples
    #define REPORT_TIMEOUT 30000 //milliseconds period for reporting to Exosite.com
    #define SENSOR_READ_TIMEOUT 5000 //milliseconds period for reading sensors in loop
  • End of Configuration Variables
    class EthernetClient client;
    Exosite exosite(cikData, &client);
    // The ‘setup()’ function is the first function that runs on the Arduino.
    // It runs completely and when complete jumps to ‘loop()’
    Serial.println(“Boot”);
    // Start up the OneWire Sensors library
    sensors.begin();
    Serial.println(“Starting Exosite Temp Monitor”);
    Serial.print(“OneWire Digital Pin Specified: “);
    Serial.println(ONEWIRE);
    Ethernet.begin(macData);
    // wait 3 seconds for connection
    delay(3000);
    // The ‘loop()’ function is the ‘main’ function for Arduino
    // and is essentially a constant while loop.
    static unsigned long sendPrevTime = 0;
    static unsigned long sensorPrevTime = 0;
    static float tempF;
    char buffer[7];
    String readParam = “”;
    String writeParam = “”;
    String returnString = “”;
    Serial.print(”.”); // print to show running
    // Read sensor every defined timeout period
    if (millis() - sensorPrevTime > SENSOR_READ_TIMEOUT) {
    Serial.println(“Requesting temperature…”);
    sensors.requestTemperatures(); // Send the command to get temperatures
    float tempC = sensors.getTempCByIndex(0);
    Serial.print(“Celsius: “);
    Serial.print(tempC);
    Serial.println(” C …DONE”);
    tempF = DallasTemperature::toFahrenheit(tempC);
    Serial.print(“Fahrenheit: “);
    Serial.print(tempF);
    Serial.println(” F …DONE”);
    sensorPrevTime = millis();
    // Send to Exosite every defined timeout period
    if (millis() - sendPrevTime > REPORT_TIMEOUT) {
    Serial.println(); //start fresh debug line
    Serial.println(“Sending data to Exosite…”);
    readParam = “”; //nothing to read back at this time e.g. ‘control&status’ if you wanted to read those data sources
    writeParam = “temp=”; //parameters to write e.g. ‘temp=65.54’ or ‘temp=65.54&status=on’
    String tempValue = dtostrf(tempF, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
    writeParam += tempValue; //add converted temperature String value
    //writeParam += “&message=hello”; //add another piece of data to send
    if ( exosite.writeRead(writeParam, readParam, returnString)) {
    Serial.println(“Exosite OK”);
    if (returnString != “”) {
    Serial.println(“Response:”);
    Serial.println(returnString);
    else {
    Serial.println(“Exosite Error”);
    sendPrevTime = millis(); //reset report period timer
    Serial.println(“done sending.”);
    delay(1000); //slow down loop
See replies #1 & #2
