Damage possibility
Hi All,
Is it valid to connect a 9V DC to the arduino Jack and in same time connect the USB cable to the computer to use its serial connection ?
And in this case will 9V DC supplied on the arduino Jack be the supply or the USB will be the supply
THANKS
Yes you can have both connected, if you have an early board there will be a jumper to select where the supply comes from.
I'd say you have a later board, selection is automatic, with both connected the 9V jack is used.
Tom.... :slight_smile:
When a high enough voltage (6.6V) is present on Vin a p-channel MOSFET switches off
the USB 5V supply (from Uno rev 3 schematic). In the absence of Vin the MOSFET is
switched on connecting the 5V rail to USB 5V.
MarkT:
But the serial interface through USB will still be working right ?
Hi, yes...
TomGeorge:
Hi, yes...
Thanks TOM :slight_smile:
Note that Vin is after the reverse polarity protection diode, so the barrel jack voltage must be a little higher to allow Vin/2 to be >3.3V and select the 5V regulator output as the source.
