Damaged internal flash in Nano 33 BLE?
Hi everyone, I hope you are well.
I was trying to study the existing code of how to write/read, format/mount internal flash of Nano 33 BLE using FAT FILESYSTEM the origin code is as follows:
#include "FlashIAPBlockDevice.h"
#include "FATFileSystem.h"
REDIRECT_STDOUT_TO(Serial)
static mbed::FATFileSystem fs("fs");
static FlashIAPBlockDevice bd(0x80000, 0x80000);
void return_error(int ret_val) {
  if (ret_val)
    printf("Failure. %d\r\n", ret_val);
    printf("done.\r\n");
void errno_error(void* ret_val) {
  if (ret_val == NULL)
    printf(" Failure. %d \r\n", errno);
    printf(" done.\r\n");
  while (!Serial);
  int error = 0;
  printf("Welcome to the filesystem example.\r\n"
         "Formatting a FAT, RAM-backed filesystem. ");
  error = mbed::FATFileSystem::format(&bd);
  return_error(error);
  printf("Mounting the filesystem on \"/fs\". ");
  error = fs.mount(&bd);
  printf("Opening a new file, numbers.txt.");
  FILE* fd = fopen("/fs/numbers.txt", "w");
  errno_error(fd);
  for (int i = 0; i < 20; i++) {
    printf("Writing decimal numbers to a file (%d/20)\r\n", i);
    fprintf(fd, "%d\r\n", i);
  printf("Writing decimal numbers to a file (20/20) done.\r\n");
  printf("Closing file.");
  fclose(fd);
  printf("Re-opening file read-only.");
  fd = fopen("/fs/numbers.txt", "r");
  errno_error(fd);
  printf("Dumping file to screen.\r\n");
  char buff[16] = {0};
  while (!feof(fd)) {
    int size = fread(&buff[0], 1, 15, fd);
    fwrite(&buff[0], 1, size, stdout);
  printf("EOF.\r\n");
  fclose(fd);
  printf("Opening root directory.");
  DIR* dir = opendir("/fs/");
  errno_error(fd);
  struct dirent* de;
  printf("Printing all filenames:\r\n");
  while ((de = readdir(dir)) != NULL) {
    printf("  %s\r\n", &(de->d_name)[0]);
  printf("Closing root directory. ");
  error = closedir(dir);
  printf("Filesystem Demo complete.\r\n");
This code was working perfectly without any issue.
Then I compiled and uploaded the following code
PLEASE DO NOT RUN IT AND UPLOAD IT IN YOUR DEVICE MIGHT DAMAGE YOUR NANO 33
static FlashIAPBlockDevice bd(0x8000, 0x8000); // origin ( bd(0x80000, 0x80000)) // change here
  if (ret_val)
  while (!Serial);
  int error = 0;
  //printf("Mounting the filesystem on \"/fs\". ");   // comment out to see what will happen
  //error = fs.mount(&bd);                                  //comment out to see  what will happen
  //return_error(error);                                       //comment out to see  what will happen
  FILE* fd = fopen("/fs/numbers.txt", "w+");
  errno_error(fd);
  fclose(fd);
  fd = fopen("/fs/numbers.txt", "r+");
  errno_error(fd);
  while (!feof(fd)) {
  printf("EOF.\r\n");
  fclose(fd);
  errno_error(fd);
  struct dirent* de;
When I uploaded the above code, I lost the serial port, and I couldn't connect it. I try to reset it using the RST push Button, and nothing happen, I applied a HIGH signal to RST pin and also nothing happens.
I tried twice push of reset button to run the bootloader, but nothing works. No LEDs are blinking.
I am afraid that I damaged the internet flash where the bootloader stored.
Could you please review the second code. I just comment out the fs.mount() function and changed the amount of bytes used to store data
Thanks in advance for your time and concern
message from Arduino developer :
" unfortunately you damaged the bootloader since it's located in flash from 0x0 to 0x10000 and the partition you tried to create
(static FlashIAPBlockDevice bd(0x8000, 0x8000); ) is in its middle.
To recover the board you need an SWD programmer with SWDIO and SWCLK connected as shown in the schematic of nano 33 BLE from the back, then just run Burn Bootloader from the IDE menu"
the question has been resolved, how can I close the session here?
Just in case there will be some additional information of use to others who inadvertently overwrite their bootloaders, I'll link the full discussion here:
Here's how you can mark the thread solved:
  • At the bottom of the first post of the thread, click the "Quick Edit" link.
  • Click on the input field that contains the thread title.
  • To the start of the title, add the text: "[solved]"
  • Click the "Save" button.
It's helpful to do that because then people browsing the forum looking for threads they can help with will know they can skip over it and people who have the same problem and find this thread while searching for a solution can zero in on it as likely providing a helpful solution.
Thanks!
