Damaged Nano Motorcarrier
Hello,
my nano motorcarrier is damaged.
I have tested all the pins and have come to the conclusion that the reset pin (the one between 5v and gnd) is defective. Is it possible to fix it or do I need a new one?
thanks in advance
What are the indications of the damaged pin? How did you test?
When you say the pin is bad, is it the physical pin or its function? Do you understand what each of the pins of the Nano are for and what they do? If not I highly recommend you get a copy of the Arduino Cookbook.
Ok, I should have told a little more: My Nano iot 33 works alone. When I connect it to the motorcarrier the system (matlab, arduino ide..) does not recognize the nano. So I have connected the two devices via a breadboard and two jumper wires. A third jumper wire now to individually check the pins. It always worked except for the mentioned pin (rst between 5v and gnd).
It is not recognized as shown in the photo.
Contact Arduino Technical Support via https://www.arduino.cc/en/contact-us/ and ensure that you give a clear and short description of what the issue is.
