Dar una orden de pulsación con un rotary
Hola a todos, me estoy haciendo una botonera para simulacion aerea, ahora mismo ya la tengo funcionando con 6 ejes y 6 botones, pero quisiera incluir 3 “Rotary Encoder”, conectados a las entradas digitales, para que al girar a derecha o izquierda cada uno de ellos me pulse unos botones como si pulsadores tradicionales se tratara, he rebuscado por google, y no encuentro nada concreto, hay muchos sketch como este:
/* Rotary encoder handler for arduino.
 * Copyright 2011 Ben Buxton. Licenced under the GNU GPL Version 3.
 * Contact: bb@cactii.net
 * Quick implementation of rotary encoder routine.
 * More info: http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
// Half-step mode?
#define HALF_STEP
// Arduino pins the encoder is attached to. Attach the center to ground.
#define ROTARY_PIN1 2
#define ROTARY_PIN2 3
// define to enable weak pullups.
#define ENABLE_PULLUPS
#define DIR_CCW 0x10
#define DIR_CW 0x20
#ifdef HALF_STEP
// Use the half-step state table (emits a code at 00 and 11)
const unsigned char ttable[6][4] = {
  {0x3 , 0x2, 0x1,  0x0}, {0x23, 0x0, 0x1,  0x0},
  {0x13, 0x2, 0x0,  0x0}, {0x3 , 0x5, 0x4,  0x0},
  {0x3 , 0x3, 0x4, 0x10}, {0x3 , 0x5, 0x3, 0x20}
#else
// Use the full-step state table (emits a code at 00 only)
const unsigned char ttable[7][4] = {
  {0x0, 0x2, 0x4,  0x0}, {0x3, 0x0, 0x1, 0x10},
  {0x3, 0x2, 0x0,  0x0}, {0x3, 0x2, 0x1,  0x0},
  {0x6, 0x0, 0x4,  0x0}, {0x6, 0x5, 0x0, 0x10},
  {0x6, 0x5, 0x4,  0x0},
#endif
volatile unsigned char state = 0;
/* Call this once in setup(). */
void rotary_init() {
  pinMode(ROTARY_PIN1, INPUT);
  pinMode(ROTARY_PIN2, INPUT);
#ifdef ENABLE_PULLUPS
  digitalWrite(ROTARY_PIN1, HIGH);
  digitalWrite(ROTARY_PIN2, HIGH);
#endif
/* Read input pins and process for events. Call this either from a
 * loop or an interrupt (eg pin change or timer).
 * Returns 0 on no event, otherwise 0x80 or 0x40 depending on the direction.
unsigned char rotary_process() {
  unsigned char pinstate = (digitalRead(ROTARY_PIN2) << 1) | digitalRead(ROTARY_PIN1);
  state = ttable[state & 0xf][pinstate];
  return (state & 0x30);
  rotary_init();
  unsigned char result = rotary_process();
  if (result) {
    Serial.println(result == DIR_CCW ? "LEFT" : "RIGHT");
que dan una salida en el “monitor serial” sobre a que lado se está girando, pero no se como hacer para traducir esa salida (Left, Right) en una pulsacion de un boton.
Gracias.
