I am completely new to the whole Arduino thing, so any help will be appriated.
I have some old washing machines that print its status (e.g. temperature, pressure and time) to its data printer (connected via RS232 DB25) every 4s or so. However, I wanted to capture these data in soft copies, so I no longer have to keep the hard copies on file. The problem is I have 4 machines, but one PC only, which is why I am thinking about using Arduino per machine to capture data onto its onboard memory before uploading it to the PC. Pretty much like a virtual printer for these machines.
Like I said I am only new to Arduino, so I am not sure if this is do-able? If so do I need anything else other than Arduino Duemilanove?
I found a device called Moxa NPort DE211, which is like a serial device server that forward data (serial -> Ethernet), which would be useful if I could somehow have the one PC listens to all machines... but I don't think it is possible.
Thank you,
J
