Data Arduino cannot be undo
Guys can i recover my data because I open a several tab I which paste and close the tab and when I realize reopen it cannot be ctrl +z
Could you explain with a little more detail please ?
so i have 2 tab of arduino which i do paste to the tab that important so i do not save it directly close the important tab, when reopen it cannot be undo
Which IDE are you using ?
Could you take a few moments to Learn How To Use The Forum.
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
[/quote]
Arduino 1.8.13 sir
Hello
give us a description in simple words what you are doing step by step and what do you will expect to be happens or not.
the Problem is that that file is replaced with another word, because I do paste something in that file and want to recover it
I have a Pro Mini that contain that file can I extract the file from pro mini to the arduino?
You can extract a HEX file from Arduino's but it has been compiled and is almost useless to you.
It will not represent the sketch you typed out.
To overwrite the current sketch on an Arduino you simply upload a new one.
but i cannot undo the previous program that had been pasted with another file
make a local copy of your sketch before you edit a new one.
so there is no solutions?
Unless you are extremely proficient in HEX programming there is no simple method.
As Paul says you should keep local copies, and version them so you can always revert to the last one.
okay thanks all
