Once again
I'm sending a bunch of values over serial, that look like this:
.420,390,419,318,319,420,293090
Where the fullstop indicates the beginning of new data, the first 6 values are battery voltages, and the last is the time returned by a function using micros() to read speed. It is sent every 350ms at 250Kbaud.
This code is handling it:
String serial_data[6];
float cell_voltages[6];
int varcounter = 0;
boolean newdata = false;
float diameter = 250.00;
float circumference;
float groundspeed;
int setgndspd = 0;
int dispmode = 0;
int buttonanlg;
int bigcharpos;
boolean button1 = false;
boolean button2 = false;
boolean button3 = false;
boolean button4 = false;
#include <LiquidCrystal.h>
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
B00111,
B01111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte UB[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000
byte RT[8] =
B11100,
B11110,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte LL[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B01111,
B00111
byte LB[8] =
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
byte LR[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11110,
B11100
byte UMB[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B11111,
B11111
byte LMB[8] =
B11111,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(9, 8, 7, 4, 2, 5);
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
lcd.begin(16, 2);
Serial.begin(250000);
circumference = diameter * 3.14;
lcd.createChar(0,LT);
lcd.createChar(1,UB);
lcd.createChar(2,RT);
lcd.createChar(3,LL);
lcd.createChar(4,LB);
lcd.createChar(5,LR);
lcd.createChar(6,UMB);
lcd.createChar(7,LMB);
// Check serial & get data
if (Serial.available() > 0){
delay(6);
while (Serial.available() > 0) {
newdata = true;
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
varcounter++;
} //breaks out of capture loop to print readstring
if (c != ',' && c != '.'){
serial_data[varcounter] += c;
if (c == '.'){
for (int i = 0; i<7; i++)
serial_data[i] = "";
varcounter = 0;
newdata = true;
// Rest of loop
if (newdata == true){
lcd.setCursor(0,0);
if (dispmode == 0){ // Main screen
boolean gotdecimal = false;
lcd.clear();
calcspeed();
char buffer[2];
bigcharpos = 0;
dtostrf(groundspeed, 2, 0, buffer);
int len = strlen(buffer);
for(int i=0; i<len; i++)
char ltr = buffer[i];
switch(ltr)
case '0':
custom0();
case '1':
custom1();
case '2':
custom2();
case '3':
custom3();
case '4':
custom4();
case '5':
custom5();
case '6':
custom6();
case '7':
custom7();
case '8':
custom8();
case '9':
custom9();
bigcharpos = bigcharpos + 4;
convertvoltages();
float totalvoltage;
for (int i=0; i<6; i++){
totalvoltage = totalvoltage + cell_voltages[i];
lcd.setCursor(8,0);
lcd.print("| ");
lcd.print(totalvoltage);
lcd.print("v");
if (dispmode == 1){ // Cell voltage display
lcd.clear();
convertvoltages();
for (int i=0; i < 6; i++){
if (i == 3){
lcd.setCursor(0,1);
lcd.print(cell_voltages[i]);
lcd.print(" ");
newdata = false;
// Button reading
buttonanlg = analogRead(A0);
if (buttonanlg < 5){
button1 = true;
dispmode = 0;
if (buttonanlg < 600 && buttonanlg > 500){
button2 = true;
dispmode = 1;
if (buttonanlg < 700 && buttonanlg > 600){
dispmode = 2;
if (buttonanlg < 800 && buttonanlg > 700){
button4 = true;
if (buttonanlg > 1000){
button1 = true;
button2 = true;
button3 = true;
button4 = true;
// FUNCTIONS
void calcspeed()
float RPS;
float RPM;
unsigned long rpms;
rpms = serial_data[6].toInt();
RPS = 1000000.0/rpms;
RPM = RPS * 60;
groundspeed = (RPM * circumference)/16666.6;
lcd.setCursor(8,1);
lcd.print(" ");
lcd.setCursor(8,1);
lcd.print(groundspeed);
void convertvoltages()
cell_voltages[i] = serial_data[i].toInt();
cell_voltages[i] = cell_voltages[i] / 100;
void custom0()
{ // uses segments to build the number 0
lcd.setCursor(bigcharpos, 0); // set cursor to column 0, line 0 (first row)
lcd.write((byte)0); // call each segment to create
lcd.write((byte)1); // top half of the number
lcd.write((byte)2);
lcd.setCursor(bigcharpos, 1); // set cursor to colum 0, line 1 (second row)
lcd.write((byte)3); // call each segment to create
lcd.write((byte)4); // bottom half of the number
lcd.write((byte)5);
void custom1()
lcd.setCursor(bigcharpos+1,0);
lcd.write((byte)2);
lcd.setCursor(bigcharpos+1,1);
lcd.write((byte)5);
void custom2()
lcd.setCursor(bigcharpos,0);
lcd.write((byte)6);
lcd.write((byte)6);
lcd.write((byte)2);
lcd.write((byte)3);
lcd.write((byte)7);
lcd.write((byte)7);
void custom3()
lcd.write((byte)6);
lcd.write((byte)6);
lcd.write((byte)2);
lcd.write((byte)7);
lcd.write((byte)7);
lcd.write((byte)5);
void custom4()
lcd.write((byte)3);
lcd.write((byte)4);
lcd.write((byte)2);
lcd.setCursor(bigcharpos+2, 1);
lcd.write((byte)5);
void custom5()
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write((byte)6);
lcd.write((byte)7);
lcd.write((byte)7);
lcd.write((byte)5);
void custom6()
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write((byte)6);
lcd.write((byte)3);
lcd.write((byte)7);
lcd.write((byte)5);
void custom7()
lcd.write((byte)1);
lcd.write((byte)1);
lcd.write((byte)2);
lcd.setCursor(bigcharpos+1, 1);
lcd.write((byte)0);
void custom8()
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write((byte)2);
lcd.write((byte)3);
lcd.write((byte)7);
lcd.write((byte)5);
void custom9()
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write((byte)2);
lcd.write((byte)5);
However, I seem to have an issue where sometimes the data ends up getting corrupted, which in turn seems to "freeze" everything. This started happening since I added the function to calculate the speed, which involves floating point math. I have a feeling maybe something is going wrong in the math, and subsequently confusing the uC?
Dan
