Data can't be uploaded to the server using gprs
Hello hi everyone, sorry i need your helps to solve this problem, i need to send data from the system to the server by using gprs connection but data can't uploaded to the server i don't know why, here below is the code please help me to solve the issue.
#include <EEPROM.h>
#include <SPI.h>
//#include <SD.h>
#include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#include <NMEAGPS.h>
#include <NeoSWSerial.h>
#include <ArduinoJson.h>
StaticJsonBuffer<100> jsonBuffer;
#define ECHOPIN 3        // Pin to receive echo pulse
#define TRIGPIN 2        // Pin to send trigger pulse
char carID[12] = "T478STK";
/* Two "independant" timed events */
const long eventTime_1_LITERS = 1000; //in ms
const long eventTime_2_GPRS = 60000; //in ms
/* When did they start the race? */
unsigned long previousTime_1 = 0;
unsigned long previousTime_2 = 0;
float distance;
float fuelHeight;
float liters;
float initialDistance = 25.66;
float surfaceArea = 490.87;
//const int cs_sd=2;
#define I2C_ADDRESS 0x3C
#define RST_PIN -1
SSD1306AsciiWire oled;
NMEAGPS gps;
gps_fix fix;
//File myFile;
float odo;
float Speed;
float alt;
NeoGPS::Location_t    lastLoc;
bool                  lastLocOK = false;
static const int RXPin = 5, TXPin = 6; //-- gps pin
static const uint32_t GPSBaud = 9600;
NeoSWSerial gpsPort(RXPin, TXPin);
const int SHOW_INTERVAL = 1;
const int INITIAL_SHOW  = (2 * SHOW_INTERVAL) - 1;
int show          = INITIAL_SHOW;
const int   LED_PIN  = 11;  //-- led on at speed limit
const float SPEED_LIMIT = 0.0; // --setup speed limit value es: 55.0; kmh default 0.0
int maxs = 0;
  pinMode (LED_PIN, OUTPUT);
  gpsPort.begin(GPSBaud);
  Wire.begin();
  DynamicJsonBuffer jsonBuffer;
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  oled.begin(& Adafruit128x64, I2C_ADDRESS);
  oled.setFont(TimesNewRoman16);
  oled.clear();
  oled.println(" ");
  oled.println("  FMS   LOGGER"); //you can custom this text
  oled.println(" ");
  oled.println("    WELCOME"); //you can custom this text
  delay(3000);
  oled.clear();
    if(!SD.begin(cs_sd)){
    oled.clear();
    oled.println(" ");
    oled.print("NO SD");
    delay(3000);
    return;}
  oled.println(" ");
  oled.print(" EEPROM OK");
  delay(2000);
  oled.clear();
    File data = SD.open("log.csv",FILE_WRITE);
    data.println("");
    data.println("Dat  Hr+  Lat  Lon  Alt  Vel  Dis" );
    data.close();
  EEPROM.get(0, odo);
  /* Updates frequently */
  unsigned long currentTime = millis();
  if ( currentTime - previousTime_1 >= eventTime_1_LITERS) {
    fuelSensor();
    previousTime_1 = currentTime;
  if (gps.available( gpsPort )) {
    gps_fix fix = gps.read();
    show = (show + 1) % SHOW_INTERVAL;
    if (fix.valid.speed && (fix.speed_kph() > SPEED_LIMIT)) {
      digitalWrite( LED_PIN, HIGH );
      digitalWrite( LED_PIN, LOW );
    if (fix.valid.location) {
      if (lastLocOK) {
        odo += fix.location.DistanceKm( lastLoc );
        Speed = (fix.speed_kph());
      lastLoc   = fix.location;
      lastLocOK = true;
    if ( Speed > maxs)
      maxs = Speed;
    if (fix.valid.altitude)
      alt = ( fix.altitude () );
    if (show == 0) {
#define MAX_CHARS 24
      char displayBufffer[MAX_CHARS];
      oled.setCursor(0, 0);
      snprintf(displayBufffer, MAX_CHARS, " DIST:  %  3d.%02d", (int)odo, (int)(odo * 100) % 100); //distance
      oled.println(displayBufffer);
      snprintf(displayBufffer, MAX_CHARS, " KMH:  %  3d.%02d", (int)Speed, (int)(Speed * 100) % 100); //speed
      oled.setCursor(2, 60);
      //oled.println(" LAT:");//LATITUDE
      oled.print(fix.latitude(), 6);
      oled.setCursor(74, 60);
      //oled.println(" LON:");//LONGITUDE
      oled.print(fix.longitude(), 6); //speed
      //if (fix.dateTime);
      //String Temps=String(fix.dateTime.hours )+(":")+(fix.dateTime.minutes)+(":")+(fix.dateTime.seconds);
      //String Date=String(fix.dateTime.date )+("/")+(fix.dateTime.month)+("/")+(fix.dateTime.year);
      //File data=SD.open("log.csv",FILE_WRITE);
      //data.println(Date +("  ")+ Temps +("  ")+ String(fix.latitude(), 6)+("  ")+String(fix.longitude(), 6)+("  ")+(alt)+("  ") +(Speed)+("  ")+(odo));
      //data.close();
      EEPROM.put(0, odo);
  /* This is my event_2 */
  if (currentTime - previousTime_2 >= eventTime_2_GPRS) {
    GPRS_DATA();
    previousTime_2 = currentTime;
void GPRS_DATA() {
  if (Serial.available())
    Serial.write(Serial.read());
  Serial.println("AT");
  Serial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  //ShowSerialData();
  Serial.println("AT+SAPBR=3,1,\"APN\",\"internet\"");//APN
  //ShowSerialData();
  Serial.println("AT+SAPBR=1,1");
  //ShowSerialData();
  Serial.println("AT+SAPBR=2,1");
  //ShowSerialData();
  Serial.println("AT+HTTPINIT");
  //ShowSerialData();
  Serial.println("AT+HTTPPARA=\"CID\",1");
  char carNumber[12] = "T478STK";
  //ShowSerialData();
  JsonObject& object = jsonBuffer.createObject();
  object.set("truckNumber", carNumber);
  object.set("truckFuel", liters, 2);
  if (fix.valid.speed)
    object.set("truckSpeed", Speed);
  object.set("truckOdometer", odo, 2);
  object.set("Latitude", fix.latitude(), 6);
  object.set("Longitude", fix.longitude(), 6);
  object.printTo(Serial);
  Serial.println(" ");
  String sendtoserver;
  object.prettyPrintTo(sendtoserver);
  delay(400);
  Serial.println("AT+HTTPPARA=\"URL\",\"http://mis.dawasa.go.tz/fm_system/data.php\""); //Server address
  delay(400);
  //ShowSerialData();
  Serial.println("AT+HTTPPARA=\"CONTENT\",\"application/json\"");
  delay(400);
  //ShowSerialData();
  Serial.println("AT+HTTPDATA=" + String(sendtoserver.length()) + ",100000");
  Serial.println(sendtoserver);
  delay(700);
  //ShowSerialData();
  delay(700);
  //ShowSerialData;
  Serial.println("AT+HTTPACTION=1");
  //ShowSerialData();
  Serial.println("AT+HTTPREAD");
  //ShowSerialData();
  Serial.println("AT+HTTPTERM");
  delay(300);
  Serial.println("AT+SAPBR=0,1"); /* Close GPRS context */
  delay(300);
  //ShowSerialData;
  //delay(300);
void fuelSensor() {
  // Start Ranging -Generating a trigger of 10us burst
  digitalWrite(TRIGPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);
  delayMicroseconds(10);
  // Distance Calculation
  distance = pulseIn(ECHOPIN, HIGH);
  distance = distance / 58;
  fuelHeight = initialDistance - distance;
  liters = (fuelHeight * surfaceArea) / 1000;
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project.
