Came across an article about how to use overlapping parts of arrays to minimize memory footprint.
The technique is useful for non changing arrays e.g. lookup tables (progmem) when you run out of memory.
(yes it uses pointers)
The technique boils down to this . e.g. you have two array's
A[] = { 1,2 3,4,5,6,7 8, 9, 10} // 10 bytes
B[] = { 7, 8, 9, 10, 11,12, 13} // 7 bytes
you can replace this with
X[]= { 1,2 3,4,5,6,7 8, 9, 10, 11,12, 13} // 12 bytes
*A = &X[0]; // 2 bytes
*B = &X[6]; //2 bytes
The 2nd storage structure gains one byte (just as example)
conclusion
- break even if overlap == pointersize
- gain if overlap > pointersize
Still interesting technique for those approaching the 32K limit of their UNO
The article - [1402.2508v1] Data Compaction - Compression without Decompression -
