Hello, I'm struggling on creating an encrypted file and append data to it.
I'm trying with one of the many samples (like https://www.dfrobot.com/blog-1001.html)
but it seems working only with small strings.
here a sample:
#include <mbedtls/aes.h>
#include <FATFileSystem.h>
#include <SDMMCBlockDevice.h>
#include <iostream>
using namespace std;
SDMMCBlockDevice block_device;
mbed::FATFileSystem fs("fs");
void encrypt(char *plainText, unsigned char *outputBuffer) {
unsigned char IV[16] = { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
const unsigned char KEY[16] = { 0x23, 0x13, 0x4d, 0x20, 0x88, 0xf3, 0xCf, 0x73, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x07, 0x00 };
mbedtls_aes_context aes;
mbedtls_aes_init(&aes);
mbedtls_aes_setkey_enc(&aes, KEY, 128);
mbedtls_aes_crypt_cbc(&aes, MBEDTLS_AES_ENCRYPT, 64, IV, (const unsigned char *)plainText, outputBuffer);
mbedtls_aes_free(&aes);
void decrypt(char *chipherText, unsigned char *outputBuffer) {
unsigned char IV[16] = { 0x00, 0x01, 0x02, 0x02, 0x04, 0x05, 0x06, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
mbedtls_aes_setkey_dec(&aes, KEY, 128);
mbedtls_aes_crypt_cbc(&aes, MBEDTLS_AES_DECRYPT, 64, IV, (const unsigned char *)chipherText, outputBuffer);
void WriteToEncryptedFile(const char *fileName, String planiText) {
FILE *f = fopen(fileName, "a");
if (f) {
int str_len1 = planiText.length() + 1;
int currIndex = 0;
int chunkSize = 16;
char char_array1[chunkSize];
unsigned char cipherTextOutput[chunkSize];
do {
planiText.toCharArray(char_array1, chunkSize, currIndex);
encrypt(char_array1, cipherTextOutput);
for (int i = 0; i < chunkSize; i++) {
Serial.print(cipherTextOutput[i], HEX);
Serial.println("");
fprintf(f, "%s", cipherTextOutput);
currIndex += chunkSize;
} while(currIndex < str_len1);
fclose(f);
while (!Serial)
String path = "/fs/crypt.txt";
Serial.println("Mounting SDCARD...");
int err = fs.mount(&block_device);
if (err) // Reformat if we can't mount the filesystem this should only happen on the first boot
Serial.println("No filesystem found, formatting... ");
err = fs.reformat(&block_device);
}a
if (err) {
Serial.println("Error formatting SDCARD ");
while (1)
Serial.println("create file");
FILE *f0 = fopen(path.c_str(), "w");
if (f0) {
fprintf(f0, "");
fclose(f0);
WriteToEncryptedFile(path.c_str(), "this is a long string this is a long string this is a long string this is a long string this is a long string this is a long string this is a long string ");
Serial.println("");
WriteToEncryptedFile(path.c_str(), "char_array2");
Serial.println("");
WriteToEncryptedFile(path.c_str(), "STOP");
Serial.println("");
