data Error_accelerometer
Hi All
I am working with ADXL 345 accelerometer with RFduino. I have programmed it for ±2g range using I2C. To convert raw data into G I am using G=rawdata*(4/2^10). To show the +1g it works fine but when I tilt other side it shows 255 instead of -1.
I am reading raw data and storing it into “int” data type variable. I tried unsigned int and signed int. but the issue stays the same. Can anyone help me out with this problem.
ADXL345_LED.ino (4.25 KB)
The code you posted does not appear to be the code you are describing.
G=rawdata*(4/2^10)
is not to found. In any case, this would produce only integer values from -2 to 2.
