I have two Arduino Mega boards which one will act as Master and the other as Slave. I want to trigger the Slave to perform a given task by sending a specific integer value, then, the Slave should reply with another value (the integer values may go from 1 up to 3 digits).
I've solved all the communication issues between them and, they are connected through the PINS 20 and 21.
The master sends an integer to the slave correctly, however, I don't know if the slave receives a value (and in the case of receiving one, probably is wrong). The slave knows that a byte has arrived and sends another integer value to the master.
For an initial test, I would like that both master and slave send/receive the same value. Thus, 1) the master sends the value X to the slave 2) the slave reads it, 3) the slave sends the same value to the master and 4) the master reads and prints the received value.
I add the complete code.
Master
const int buttonSel = 50;//button to Select options
const int buttonStart = 53; //button to Start option
const int buttonStop = 52; //button to Stop option
const int Marcia = 32; //Initiates Marcia of the TX module
const int PR17 = 22; //PR17 relay of the TX module
const int PR16 = 24; //PR16 relay of the TX module
const int PR15 = 26; //PR15 relay of the TX module
const int PR27 = 28; //PR27 relay of the TX module
const int PR26 = 30; //PR26 relay of the TX module
const int PR25 = 31; //PR25 relay of the TX module
const int PR11 = 33; //PR11 relay of the TX module
const int PR10 = 34; //PR10 relay of the TX module
const int PR9 = 35; //PR9 relay of the TX module
const int PR5 = 36; //PR5 relay of the TX module
const int PR6 = 37; //PR6 relay of the TX module
const int PR7 = 38; //PR7 relay of the TX module
const int PR23 = 39; //PR23 relay of the TX module
const int PR22 = 40; //PR22 relay of the TX module
const int PR21 = 41; //PR21 relay of the TX module
int programCount = 0;//variable to move through the program
int delay_ = 1000;
int read;
int pass = 0; // integer to indicate if at least one pins doesn't pass 0-OK 1-FAIL
int Error = 0; // integer to indicate that there is an error during the checking 0-NO 1-YES
int x; int y;
const byte SLAVE_ADDRESS = 42;
const byte MY_ADDRESS = 25;
#include <Wire.h>
#include <hd44780.h> // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
Wire.begin ();
lcd.begin(20, 4);
Serial.begin (9600);
lcd.setCursor(0, 0);
programCount = 0;//start at the beginning
pinMode(buttonSel, INPUT); //set the button as an input
pinMode(buttonStart, INPUT); //set the button as an input
pinMode(buttonStop, INPUT); //set the button as an input
lcd.print("Select");
Serial.println("CLEARDATA");
Serial.println("LABEL, Time, Device, Link, Check");
Wire.beginTransmission (SLAVE_ADDRESS);
switch (programCount)
case 0: // This case option remains the "Select" option idle
if (digitalRead(buttonSel) == HIGH)
programCount = 1;
case 1:
static const uint8_t arraypin[] = {PR5, PR6, PR7, PR9, PR10, PR11, PR15, PR16, PR17, PR21, PR22, PR23, PR25, PR26, PR27};
x = 15;
lcd.clear();
lcd.print("Edilbox");
delay(delay_);
programCount = 2;
if (digitalRead(buttonStart) == HIGH)
lcd.clear();
lcd.print("Start Edilbox");
digitalWrite(Marcia, LOW);
delay(2000);
digitalWrite(Marcia, HIGH);
for (int i = 0; i < x; i++)
for (int j = 0; j < x; j++)
if (i == j)
digitalWrite(arraypin[j], LOW);
Wire.write (y = arraypin[j]);
Serial.println("Transmiting from Master");
Serial.println(y);
Wire.requestFrom(42, 1);
if (Wire.available() != 0)
Serial.println("Receiving from Slave");
int y = Wire.read();
Serial.println(y, DEC);
digitalWrite(arraypin[j], HIGH);
delay(delay_);
if ((i == j) && (digitalRead(arraypin[j]) == LOW))
pass = 0;
delay(delay_);
else if ((i != j) && (digitalRead(arraypin[j]) == HIGH))
pass = 0;
delay(delay_);
else if ((i != j) && (digitalRead(arraypin[j]) == LOW))
pass = 1;
Error = 1;
delay(delay_);
// NOTHING
if (digitalRead(buttonStop) == HIGH)
lcd.clear();
lcd.print("Stop Edilbox");
delay(delay_);
case 2:
lcd.clear();
lcd.print("R9");//print the number
delay(delay_);
programCount = 3;
lcd.clear();
lcd.print("Start R9");//print the number
delay(delay_);
lcd.clear();
lcd.print("Stop R9");//print the number
delay(delay_);
case 3:
lcd.clear();
lcd.print("R7");//print the number
delay(delay_);
programCount = 0;
lcd.clear();
lcd.print("Start R7");//print the number
delay(delay_);
lcd.clear();
lcd.print("Stop R7");//print the number
delay(delay_);
Wire.endTransmission ();
Slave
const int STOP = 8; //STOP of the RX module
const int CLAX = 9; //CLAX of the RX module
const int START = 10; //START of the RX module
const int LAMP = 11; //LAMP of the RX module
int delay_ = 10000;
int x; int flag = 0; int y;
const byte MY_ADDRESS = 42;
const byte MASTER_ADDRESS = 25;
int LED = 13;
#include <Wire.h>
Wire.begin (MY_ADDRESS);
lcd.begin(20, 4);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
pinMode(STOP, INPUT); digitalWrite(STOP, HIGH);
pinMode(CLAX, INPUT); digitalWrite(CLAX, HIGH);
pinMode(START, INPUT); digitalWrite(START, HIGH);
pinMode(LAMP, INPUT); digitalWrite(LAMP, HIGH);
delay(delay_);
Serial.println("Receiving from M");
void receiveEvent(int howMany) {
flag = 1;
if (y == 0)
digitalWrite(LED, HIGH);
void requestEvent() {
if (flag == 1)
Wire.write(y=50);
flag = 0;
I've tried to modify the received bytes, insert begin transmission at the slave and using different type of values.
Any clue how to exchange a single integer value?
